I downloaded the “Community Edition” of VP UML for Eclipse (both sdeceec_20040108.jar and sdeceec_20040108_no_install.zip) . However, it will not run. BTW, the installation instructions are inaccessible – the URL (http://www.visual-paradigm.com/installationInstruction.php?product=sdeceec&platform=JavaEnabledPlatforms) yields a blank page, in multiple browsers.
Environment :
OS: Debian Linux (kernel 2.6.0)
Java: 1.4.2 (from Sun)
Eclipse: 2.1.1 (debian package)
I have tried both the plugin directory created by the jar installer and using the plugin directory from the no_install zip file. The first time I accessed the plugin it prompted me for licensing information. I provided the license key and it has not prompted me again. Whenever I try to create a new class diagram (I haven’t tried any other diagram types, because I only want a class diagram), I see the following output:
------------------------------- VPSDEECMain.<init>
------------------------------- VPSDEECMain.startUp
cannot load E1 library
cannot load I1 library
cannot load W1 library
cannot register
at this point a dialog appears reporting “Unable to create part: Class Diagram1”. The error log contains this stack trace :
java.lang.NoClassDefFoundError: sun/awt/windows/WEmbeddedFrame
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:123)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.findClass(DelegatingURLClassLoader.java:922)
at org.eclipse.core.internal.plugins.PluginClassLoader.internalFindClassParentsSelf(PluginClassLoader.java:166)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.findClassParentsSelf(DelegatingURLClassLoader.java:485)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.loadClass(DelegatingURLClassLoader.java:882)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.loadClass(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302)
at v.fir.a(Unknown Source)
at com.vp.vpsde.ec.editors.DiagramEditor.createPartControl(Unknown Source)
at org.eclipse.ui.internal.PartPane$4.run(PartPane.java:141)
at org.eclipse.core.internal.runtime.InternalPlatform.run(InternalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane.java:137)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java:186)
at org.eclipse.ui.internal.EditorWorkbook.createPage(EditorWorkbook.java:387)
at org.eclipse.ui.internal.EditorWorkbook.add(EditorWorkbook.java:123)
at org.eclipse.ui.internal.EditorArea.addEditor(EditorArea.java:55)
at org.eclipse.ui.internal.EditorPresentation.openEditor(EditorPresentation.java:351)
at org.eclipse.ui.internal.EditorManager$2.run(EditorManager.java:585)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:69)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:574)
at org.eclipse.ui.internal.EditorManager.openInternalEditor(EditorManager.java:668)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:459)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:431)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2054)
at org.eclipse.ui.internal.WorkbenchPage.access$700(WorkbenchPage.java:91)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:1991)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:1986)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:1919)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:1911)
at v.bul.run(Unknown Source)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:98)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:1618)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1436)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
at org.eclipse.core.internal.boot.InternalBootLoader.run(InternalBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
What should I look for and what can I try to correctly and completely install VP-UML for Eclipse?
