I am using the evaluation of DB-VA and the Flight.vpp example to generate the code. When I run the generated code, it threw the exception as following:
java.lang.SecurityException: class “org.hibernate.dialect.DialectFactory”'s signer information does not match signer information of other classes in the same package
at java.lang.ClassLoader.checkCerts(ClassLoader.java:775)
at java.lang.ClassLoader.preDefineClass(ClassLoader.java:487)
at java.lang.ClassLoader.defineClass(ClassLoader.java:614)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:268)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
at org.hibernate.cfg.SettingsFactory.determineDialect(SettingsFactory.java:378)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:110)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:1881)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1174)
at org.orm.util.ORMSessionFactory.(ORMSessionFactory.java:17)
at org.orm.util.ThreadBaseSessionController.(ThreadBaseSessionController.java:26)
at org.orm.PersistentManager.(PersistentManager.java:77)
at airport.FlightPersistentManager.(FlightPersistentManager.java:31)
at airport.FlightPersistentManager.instance(FlightPersistentManager.java:41)
at ormsamples.CreateFlightData.main(CreateFlightData.java:46)
Does anyone know what happens?
Thank you
