Java Problem
Im trying to install an aplication and I got some error problem on JAVA
http://img3.imageshack.us/img3/1415/javapu8.jpg
there are so many javas I tried alot and now im confused, here is a picture of Javas I have Installed
http://img16.imageshack.us/img16/4108/java2kw2.jpg
I already tried:
JDK 5.0 Update 7 includes the JVM technology
The J2SE Development Kit (JDK) supports creating J2SE applications.
and:
JRE 5.0 Update 7 includes the JVM technology
The J2SE Runtime Environment (JRE) allows end-users to run Java applications. More info…
http://java.sun.com/products/archive/j2se/5.0_07/index.html
I really need this program, and I dont know what to do I need Help ASP
im running on windows xp
Hi Goliath,
Could you please try to define EXE4J_JAVA_HOME environment variable to point to JDK, or add java path to PATH variable to see if your problem can be solved?
BTW, you can define EXE4J_JAVA_HOME environment variable in System Properties dialog (see image).
Hey I just tried to do this at my school and it still says the same d*** thing!
[quote=LilianWong]Hi Goliath,
Lilian Wong[/quote]
Yes, i am getting same problem, when i am installing, and i have tried all, but didnt get solution
Can you try with the latest installer and see is it work?
http://www.visual-paradigm.com/download/
Rain Wong
I have downloaded the latest update, and now I have the same problem. I have tried the solution at the top of this page and it hasn’t solved it. Any suggestions please?
