hi all,
how to connect ur java application to sql server database.
thanks Etele
hi all,
thanks Etele
Hi Etele,
Firstly, you will need a JDBC driver for your database which will also need to be put into your classpath.
Here is a snippet code which should get you started.
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.sql.Statement;
class JDBCTest {
public static void main (String args[]) {
JDBCTest db = new JDBCTest();
public JDBCTest() {
Connection connection = null;
Statement stmnt = null;
ResultSet rs = null;
try {
// Load the JDBC connector driver
Class.forName(“oracle.jdbc.driver.OracleDriver”);
String url = “jdbc:oracle:thin:@neptune:1521:EJDB”;
String usr = “username”;
String pwd = “pwd”;
connection = DriverManager.getConnection(url,usr,pwd);
stmnt = connection.createStatement();
String qry = “SELECT * FROM STUDENT”;
rs = stmnt.executeQuery(qry);
while ( rs.next() ) {
String firstColumn = rs.getString(1);
// do your own stuff here
System.out.println(firstColumn);
catch (SQLException sqlEx) {
sqlEx.printStackTrace();
catch(Exception ex) {
ex.printStackTrace();
finally {
if(rs != null) {
try {
rs.close();
} catch (SQLException e) {}
if(stmnt != null) {
try {
stmnt.close();
if(connection!= null) {
try {
connection.close();
//connection.close() throws an SQLException, but we can't recover at this point
catch (SQLException sqlEx) {}
This is a basic example only and there are many other examples online.
Hope this helps.
Martyn
