first of all, your product is great and we like to buy it soon. But we need the eclipse-plugin version. Our problem is, as soon as we start the plugin, eclipse 3.2 stops and an error-window pops up which says:
“JVM terminated. Exit code=1073807364
C:\Window\system\javw.exe
-Xms40m
-Xmx:512m
May I know if this problem is repeatable? Second, there should have a log file produced inside the Eclipse folder, with name like hs_err_pid123.log. Could you send me that file? Thank you in advance!
Thank you for the log file. May I know if this problem is repeatable? Also, cold you let me know how did you start the tool (e.g. inside Eclipse, using launcher, start menu, etc…)?
Sorry im not sure what you mean. The problem happenes every start.
I tried it in different ways. With launcher or start menu it stop right after the main windows pops up. If i start it inside eclispe it stop as soon i use Modeling>Start SED-EC or try to open a project is SED-view.
Thank you for your reply. Would you mind helping me to do one thing? If you could help, we will be able to identify and solve this problem easier. Here are the steps:
Delete the vp.log file
Try to start SDE-EC, which produces the problem you mentioned
At this point, the log file should be created with the error information filled in.
Post the log file here.
I would be grateful if you could help! Thank you in advance!
First i deleted the vp.log. After i started it as a eclipse-plugin with Modeling>Start SDE-EC it worked!!!
The vp.log was:
Wed Sep 20 10:13:16 CEST 2006] [message] [ Wed Sep 20 10:13:16 CEST 2006]: Start Smart Development Environment Professional Edition for Eclipse [SDE PE-EC]: 3.3 (sp2_20060908)
Wed Sep 20 10:13:46 CEST 2006] [warning] <<<<<<<<<<>>>>>>>>>>>
Wed Sep 20 10:13:46 CEST 2006] [warning] << miss persistance code model, but ignore to prepare codemodel from uml model >>
Wed Sep 20 10:13:46 CEST 2006] [error] cannot call load_setCodeSignature(…) here
I don´t know what happened… Means that, it comes from the logfile?
after a few starts it happened again… here ist the log:
Wed Sep 20 12:18:56 CEST 2006] [warning] java.lang.NullPointerException
at v.ieki.partClosed(:147)
at org.eclipse.ui.internal.PartListenerList2$3.run(PartListenerList2.java:98)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.PartListenerList2.fireEvent(PartListenerList2.java:53)
at org.eclipse.ui.internal.PartListenerList2.firePartClosed(PartListenerList2.java:96)
at org.eclipse.ui.internal.PartService.firePartClosed(PartService.java:103)
at org.eclipse.ui.internal.WWinPartService.reset(WWinPartService.java:229)
at org.eclipse.ui.internal.WWinPartService.pageClosed(WWinPartService.java:199)
at org.eclipse.ui.internal.WorkbenchWindow.firePageClosed(WorkbenchWindow.java:1187)
at org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(WorkbenchWindow.java:747)
at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1486)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:622)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:598)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindow.java:713)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:711)
at org.eclipse.jface.window.WindowManager.close(WindowManager.java:109)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:712)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:709)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:639)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:839)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:837)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:812)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:619)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:736)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:682)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:159)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:257)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1606)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3248)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1539)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1634)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1918)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:443)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3334)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:1923)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2966)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:95)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Wed Sep 20 12:18:57 CEST 2006] [warning] java.lang.NullPointerException
at v.icxo.o(:318)
at v.icxo.t(:314)
at v.qcb.n(:235)
at v.qcb.k(:376)
at v.qcb.o(:380)
at v.qcb.i(:213)
at v.w.i(:39)
at com.vp.vpsde.ec.VPSDEECMain.i(:507)
at com.vp.vpsde.ec.VPSDEECMain.shutdown(:498)
at org.eclipse.core.internal.compatibility.PluginActivator.stop(PluginActivator.java:46)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$3.run(BundleContextImpl.java:1036)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:1032)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:396)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.stop(AbstractBundle.java:400)
at org.eclipse.core.runtime.internal.adaptor.BundleStopper.basicStopBundles(BundleStopper.java:86)
at org.eclipse.core.runtime.internal.adaptor.BundleStopper.stopBundles(BundleStopper.java:73)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook.frameworkStopping(EclipseAdaptorHook.java:156)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStopping(BaseAdaptor.java:288)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:529)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:440)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.java:41)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:423)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:193)
at v.icxo.o(:318)
at v.icxo.t(:314)
at v.qcb.n(:235)
at v.qcb.k(:376)
at v.qcb.o(:380)
at v.qcb.i(:213)
at v.w.i(:39)
at com.vp.vpsde.ec.VPSDEECMain.i(:517)
at com.vp.vpsde.ec.VPSDEECMain.i(:523)
Wed Sep 20 12:19:53 CEST 2006] [message] [ Wed Sep 20 12:19:53 CEST 2006]: Start Smart Development Environment Professional Edition for Eclipse [SDE PE-EC]: 3.3 (sp2_20060908)
Wed Sep 20 12:19:53 CEST 2006] [error] java.awt.HeadlessException
at java.awt.GraphicsEnvironment.checkHeadless(Unknown Source)
at java.awt.Window.(Unknown Source)
at java.awt.Frame.(Unknown Source)
at javax.swing.SwingUtilities$SharedOwnerFrame.(Unknown Source)
at javax.swing.SwingUtilities.getSharedOwnerFrame(Unknown Source)
at javax.swing.JDialog.(Unknown Source)
at v.wnm.(:49)
at v.ityq.i(:307)
at v.C.a(:13)
at v.zup.a(:80)
at v.zup.i(:61)
at com.vp.vpsde.ec.VPSDEECMain$2.run(:291)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Wed Sep 20 12:19:53 CEST 2006] [message] Unhandled event loop exception during blocked modal context.
Wed Sep 20 12:19:53 CEST 2006] [message] org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.SWT.error(SWT.java:3374)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.SWT.error(SWT.java:3297)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:126)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3325)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2971)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:158)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:326)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:479)
Wed Sep 20 12:19:53 CEST 2006] [message] at com.vp.vpsde.ec.VPSDEECMain.i(:564)
Wed Sep 20 12:19:53 CEST 2006] [message] at com.vp.vpsde.ec.VPSDEECMain.i(:370)
Wed Sep 20 12:19:53 CEST 2006] [message] at v.inba.run(:15)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:254)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:539)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:488)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:400)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3348)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2968)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1914)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:95)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
Wed Sep 20 12:19:53 CEST 2006] [message] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Wed Sep 20 12:19:53 CEST 2006] [message] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
Wed Sep 20 12:19:53 CEST 2006] [message] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
Wed Sep 20 12:19:53 CEST 2006] [message] at java.lang.reflect.Method.invoke(Unknown Source)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.launcher.Main.run(Main.java:977)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.core.launcher.Main.main(Main.java:952)
Wed Sep 20 12:19:53 CEST 2006] [message] Caused by: java.lang.NullPointerException
Wed Sep 20 12:19:53 CEST 2006] [message] at v.icxo.i(:334)
Wed Sep 20 12:19:53 CEST 2006] [message] at com.vp.vpsde.ec.VPSDEECMain$2$1.run(:315)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
Wed Sep 20 12:19:53 CEST 2006] [message] at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
Wed Sep 20 12:19:53 CEST 2006] [message] … 35 more
I am sorry for replying you late. We guess that there is a conflict with our tool and other plugin that you have installed in the same Eclipse folder. I will prepare a special build for you. Please be patient.
