I downloaded the community edition, but it asks for extensions *.slip, *.txt or *.eml and even if i change the extension or just use the evaluatekey.zvpl I was sent, I get the same error as Jorge here.
You don’t need to see the content of the key in order to use it. Just open the program (VP-UML/SDE/DB-VA), when it asks for the key and then you can select the key file and import it.
You do not need to open the license key file manually. When the application starts, the License Key Manager will prompt you to import the license key. You just need to press the Import Key button, then press “…” to open the file choose and locate the key file from your hard drive. After that the key will be imported automatically.
Actually you do not need to open the license key file manually. When the application starts, the License Key Manager will prompt you to import the license key. You just need to press the Import Key button, then press “…” to open the file choose and locate the key file from your hard drive. After that the key will be imported automatically.
