is it possible make a CLEAN collaboration diagram from seq.diag ?
I get too many details and i’m not be able(is possible?) to clean the collaboration diag result.
I may had only the principal method call.
The key is to work in primitive sequence diag or in the destination colll.diag ?
I have tryied without success to redistribute the line and arrows in result diag
Sorry but I cannot get what your problem is, can you provide a sample of your current situation, that is the source sequence diagram, the currently generated collaboration diagram, and the desired collaboration diagram you want to get? Thank you very much.
A ) made sequence diag : the source
B) convert in collaboration diagram (the destionation) inside th sequence diagram
C.1) the collaboration diag is a cloud with a lots of detail, too many.
C.2) I can not redistribute the line, the image, the size, the picture inside the collaboratione diag
The goal I need : make a collaboration dfiagram with only the necessary me
