UML 5.0. Professional Edition. Evaluation Copy.
I was using 20050624y build before trying to report this bug, then downloaded latest 20051020a and tried it. Still see this problem.
I’m using Windows XP SP2, JDK 1.5.0_04 (Sun Implementation).
To show this issue, simply create a blank UML 2.0 project, save it. Set all of your tool panes to be autohide. Quit UML 5.0. Start your windows task manager, watch the memory usage in process tab. You can add ‘Page Fault’ or other info as well.
Now start your VP UML, initially it’s using around 80M memory. That’s ok. Now don’t do any thing, just move your mouse above those docked tool panes, move it up and down, ‘Property’, ‘Diagram Overview’, ‘Documentation’ …’ Diagram Navigator’, ‘Model’, … Stay around 1 or 2 seconds on each tab, you don’t need to click on it.
Watch the memory cosumption of the VP. It’s growing, 4k, sometimes 12K,
etc. keep growning. I really don’t think repeatly moving mouse around these tabs will use memory continuously. Unless you tell me that’s normal.
I was working on a project with about 30 classes and 3 class diagrams only. After 3 hours work, VP is using nearly 600M memory. Anyway, my above simply blank project will demonstrate the bug.
