I have found the Engine parameter in Database Configuration… But even if I check the InnoDB value, my tables are generated as MyISAM. This problem do not come from the server side (as I can ALTER each table to ENGINE=InnoDB) but from Visual Paradigm (the ENGINE is not specified to the SQL code).
Congratulation, Visual Paradigm is still a wonderful software!
Alain
