I’m using the Eval version 1.1 (Build sp2_20060922) as we are currently looking to document all of our ITIL Processes.
I would like to rename the properties, or the participants or the message but it seems that the name is put back to its creation value when I cliked on the Ok to validate my documentation.
Besides I don’t see those reported in the published documentation. though it is partially present in the PDF report.
tough there is no way to access them idependantly!
Could you tell me if it’s limitation of the eval version?
After several testings, I could reproduce this problem with:
Message Flow > Message > From/To (Participant)
I already asked our engineers to fix this issue. Could you suggest other paths (if any)?
Do you mean Project Publisher? I think we could support it. Please let me know if you were talking about Project Publisher.
Because of the limitation of size, we could only dill down to at most 2 levels. I will check with our engineers to see if we could present the information in any other ways.
I will check the paths one by one. By the way, the ‘problem path’ I mentioned in the original post is fixed. I will check for the remaining paths and come back to you.
