hello,
For school we need to make a software program, and also a database (sql)
So we have made this ERD, but visual paradigm automatically makes a column called rolrolID in table "gebruiker’ . we cannot figure out why ![]()
thnx in advance
hello,
thnx in advance
Hi slammie,
Can you provide the steps to produce this ERD?
Did you model it directly in Visual Paradigm? Or reverse from SQL / Database?
hello kit,
i made this directly in paradigm.
first i made every table and column, then the relationships.
last relationship i made was the one betwene Rol and Gebruiker (Roll and User, translated)
today i went into the properties of that specific relationship, and saw that it had a 1 to zero or more. altough this is correct, becuz this is a exercise app for school, and in the beginning there can be a roll without user. i chaned that relation to the following: 1 to 1 or many. after that i was able to delete that extra column.
i think everything in this erd is ok now, but i dont dare to say 100% haha.
best regards,
slammers
Hi slammie,
I guess you created the foreign key column, then when you create relationship, it’ll show a dialog, if you didn’t select your foreign key column, then it’ll generate a new column for you.
