VP IDE integration dont work in NB4.1, though it seemed to work in NB4.1beta.
Module will not load!
Details from exception report:
Annotation: From file: MultiFileObject@f21b01[nbfs://nbhost/SystemFileSystem/xml/lookups/NetBeans_org_netbeans_modules_pdf/DTD_XML_PDFSettings_1_0.instance]
java.lang.ClassNotFoundException: Will not load classes from default package (DTD_XML_PDFSettings_1_0)
at org.netbeans.ProxyClassLoader.loadClass(ProxyClassLoader.java:147)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at org.openide.loaders.InstanceSupport.findClass(InstanceSupport.java:477)
at org.openide.loaders.InstanceSupport.instanceClass(InstanceSupport.java:127)
at org.openide.loaders.InstanceDataObject$Ser.instanceClass(InstanceDataObject.java:1121)
at org.openide.loaders.InstanceSupport.instanceCreate(InstanceSupport.java:197)
at org.openide.loaders.InstanceDataObject$Ser.instanceCreate(InstanceDataObject.java:1180)
at org.openide.loaders.InstanceDataObject.instanceCreate(InstanceDataObject.java:692)
at org.netbeans.core.xml.FileEntityResolver.findLookup(FileEntityResolver.java:158)
at org.netbeans.core.xml.FileEntityResolver.access$200(FileEntityResolver.java:57)
at org.netbeans.core.xml.FileEntityResolver$Lkp.update(FileEntityResolver.java:490)
at org.netbeans.core.xml.FileEntityResolver$Lkp.beforeLookup(FileEntityResolver.java:456)
at org.openide.util.lookup.ProxyLookup$R.myBeforeLookup(ProxyLookup.java:422)
at org.openide.util.lookup.ProxyLookup$R.computeResult(ProxyLookup.java:355)
at org.openide.util.lookup.ProxyLookup$R.allItems(ProxyLookup.java:345)
at org.openide.loaders.InstanceDataObject.getCookiesLookup(InstanceDataObject.java:594)
at org.openide.loaders.InstanceDataObject.getCookiesLookup(InstanceDataObject.java:575)
at org.openide.loaders.InstanceDataObject.getCookieFromEP(InstanceDataObject.java:540)
at org.openide.loaders.InstanceDataObject.getCookie(InstanceDataObject.java:561)
at org.openide.loaders.FolderLookup$ICItem.init(FolderLookup.java:412)
at org.openide.loaders.FolderLookup$ICItem.instanceOf(FolderLookup.java:459)
at org.openide.util.lookup.InheritanceTree$1VerifyJob.before(InheritanceTree.java:333)
at org.openide.util.lookup.AbstractLookup$ISE.recover(AbstractLookup.java:1148)
at org.openide.util.lookup.AbstractLookup.lookup(AbstractLookup.java:374)
at org.openide.util.lookup.ProxyLookup$R.initResults(ProxyLookup.java:238)
at org.openide.util.lookup.ProxyLookup$R.myBeforeLookup(ProxyLookup.java:424)
at org.openide.util.lookup.ProxyLookup$R.beforeLookup(ProxyLookup.java:442)
at org.openide.util.lookup.ProxyLookup$R.myBeforeLookup(ProxyLookup.java:430)
at org.openide.util.lookup.ProxyLookup$R.allInstances(ProxyLookup.java:329)
at org.openide.filesystems.URLMapper.getInstances(URLMapper.java:233)
at org.openide.filesystems.URLMapper.findURL(URLMapper.java:96)
at org.openide.filesystems.FileObject.getURL(FileObject.java:715)
at org.openide.loaders.BrokenDataShadow.checkValidity(BrokenDataShadow.java:185)
at org.openide.loaders.ShadowChangeAdapter.checkBrokenDataShadows(ShadowChangeAdapter.java:39)
at org.openide.loaders.ShadowChangeAdapter.operationPostCreate(ShadowChangeAdapter.java:55)
at org.openide.loaders.DataLoaderPool.fireOperationEvent(DataLoaderPool.java:213)
at org.openide.loaders.DataObjectPool.notifyCreation(DataObjectPool.java:423)
at org.openide.loaders.DataObjectPool.notifyCreationAll(DataObjectPool.java:438)
at org.openide.loaders.DataObjectPool.exitAllowConstructor(DataObjectPool.java:96)
at org.openide.loaders.DataObjectPool.handleFindDataObject(DataObjectPool.java:113)
at org.openide.loaders.DataLoader.findDataObject(DataLoader.java:358)
at org.openide.loaders.DataLoaderPool.findDataObject(DataLoaderPool.java:386)
at org.openide.loaders.FolderList.createBoth(FolderList.java:701)
at org.openide.loaders.FolderList.getObjects(FolderList.java:512)
at org.openide.loaders.FolderList.access$200(FolderList.java:50)
at org.openide.loaders.FolderList$ListTask.run(FolderList.java:880)
at org.openide.util.Task.run(Task.java:189)
at org.openide.util.RequestProcessor$Task.run(RequestProcessor.java:330)
[catch] at org.openide.util.RequestProcessor$Processor.run(RequestProcessor.java:721)
