when I try to open the uml files of a project in NetBeans by right clicking on it and clicking on “Open VP-UML SE”, NetBeans just closes down. It doesn’t even give an error.
It could be that I did something wrong installing Visual Paradigm. Also, I have to start VP via this file “C:\Program Files\Visual Paradigm for UML 10.2\scripts\VP-UML”. If I click on the normal shortcut it doesn’t do anything but showing the red start window.
In NetBeans’s bin file I found an error file.
This is what it says:
A fatal error has been detected by the Java Runtime Environment:
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x711ce181, pid=6080, tid=5084
JRE version: Java™ SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
Java VM: Java HotSpot™ Client VM (24.45-b08 mixed mode windows-x86 )
Problematic frame:
C [aticfx32.dll+0x8e181]
Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
If you would like to submit a bug report, please visit:
http://bugreport.sun.com/bugreport/crash.jsp
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x5bb97400): JavaThread “Thread-8” [_thread_in_native, id=5084, stack(0x51190000,0x51390000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x01001403, EBX=0x003c1038, ECX=0x5138e958, EDX=0x00000280
ESP=0x5138e91c, EBP=0x5138e944, ESI=0x00000000, EDI=0x5138e9b8
EIP=0x711ce181, EFLAGS=0x00010287
Top of Stack: (sp=0x5138e91c)
0x5138e91c: 5138e958 00000000 5138e99c 003c1038
0x5138e92c: 711cb0e6 00000000 00000140 00000000
0x5138e93c: 5138e99c 003c1038 5138e974 711a28b1
0x5138e94c: 5138e958 5138ed68 5138e99c 50d94078
0x5138e95c: 00000000 5138e9b8 00000108 00000001
0x5138e96c: 00000000 80000740 5138e984 711a0724
0x5138e97c: 80000700 01021590 5138eac4 61c482ec
0x5138e98c: 80000740 5138ed68 54e7a268 003c1038
Instructions: (pc=0x711ce181)
0x711ce161: 26 8b 06 ff 75 08 8b ce ff 50 44 8b 4d fc 8b 55
0x711ce171: f8 89 97 d4 00 00 00 89 8f e8 00 00 00 eb 08 51
0x711ce181: 8b 06 8b ce ff 50 44 85 c0 75 43 8b 4f 54 81 f9
0x711ce191: 03 05 00 01 75 2a bb 01 00 00 00 39 5e 04 76 2e
Register to memory mapping:
EAX=0x01001403 is an unknown value
EBX=0x003c1038 is an unknown value
ECX=0x5138e958 is pointing into the stack for thread: 0x5bb97400
EDX=0x00000280 is an unknown value
ESP=0x5138e91c is pointing into the stack for thread: 0x5bb97400
EBP=0x5138e944 is pointing into the stack for thread: 0x5bb97400
ESI=0x00000000 is an unknown value
EDI=0x5138e9b8 is pointing into the stack for thread: 0x5bb97400
Stack: [0x51190000,0x51390000], sp=0x5138e91c, free space=2042k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [aticfx32.dll+0x628b1]
C [aticfx32.dll+0x60724]
C [atigktxx.dll+0x82ec]
C [atigktxx.dll+0x8178]
C [atigktxx.dll+0x4594]
C [atioglxx.dll+0x4223f]
C [atioglxx.dll+0xc04b65]
C [atioglxx.dll+0xbcecb9]
C [atioglxx.dll+0x100e47]
C [atioglxx.dll+0xaaaa81]
C [atioglxx.dll+0xaaa568]
C [atioglxx.dll+0x1782e]
C [atioglxx.dll+0x1ae07]
C [OPENGL32.DLL+0x3c654]
C [OPENGL32.DLL+0x3c6b7]
C [OPENGL32.DLL+0x45658]
C [OPENGL32.DLL+0x45dd4]
C [GDI32.dll+0x45ae0]
C [awt.dll+0x97a24]
j sun.awt.Win32GraphicsDevice.getMaxConfigsImpl(I)I+0
j sun.awt.Win32GraphicsDevice.getMaxConfigs(I)I+10
j sun.awt.Win32GraphicsDevice.getConfigurations()[Ljava/awt/GraphicsConfiguration;+69
j v.aynh.c()Ljava/awt/Rectangle;+20
j v.aynh.a(Lv/aynh;)Ljava/awt/Rectangle;+1
j v.aynk.run()V+8
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
V [jvm.dll+0x13f1fa]
V [jvm.dll+0x202aee]
V [jvm.dll+0x13f3c5]
V [jvm.dll+0x13f427]
V [jvm.dll+0xeb81f]
V [jvm.dll+0x16042c]
V [jvm.dll+0x160e67]
V [jvm.dll+0x1a49f9]
C [msvcr100.dll+0x5c556]
C [msvcr100.dll+0x5c600]
C [kernel32.dll+0x1336a]
C [ntdll.dll+0x39f72]
C [ntdll.dll+0x39f45]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j v.aynk.run()V+8
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x5bb97400 JavaThread “Thread-8” [_thread_in_native, id=5084, stack(0x51190000,0x51390000)]
0x5bb97000 JavaThread “Image Fetcher 0” daemon [_thread_blocked, id=5908, stack(0x50e80000,0x51080000)]
0x4fe34400 JavaThread “Inactive RequestProcessor thread [Was:Explorer Actions/org.netbeans.modules.openide.explorer.ExplorerActionsImpl$ActionStateUpdater]” daemon [_thread_blocked, id=5284, stack(0x50ac0000,0x50cc0000)]
0x4fe33800 JavaThread “Inactive RequestProcessor thread [Was:org.netbeans.spi.debugger.ui.EditorContextDispatcher$AddRemoveFileListenerInEQThread/org.netbeans.spi.debugger.ui.EditorContextDispatcher$AddRemoveFileListenerInEQThread]” daemon [_thread_blocked, id=5044, stack(0x508b0000,0x50ab0000)]
0x4fe30000 JavaThread “Inactive RequestProcessor thread [Was:System clipboard synchronizer/org.netbeans.NbClipboard$GetContents]” daemon [_thread_blocked, id=6052, stack(0x505f0000,0x507f0000)]
0x4fe2f000 JavaThread “Inactive RequestProcessor thread [Was:SelectedNodesScheduler/org.netbeans.modules.parsing.impl.SelectedNodesScheduler$1]” daemon [_thread_blocked, id=5580, stack(0x542c0000,0x544c0000)]
0x4fe36800 JavaThread “Inactive RequestProcessor thread [Was:org.netbeans.modules.project.ui.actions.LookupSensitiveAction/org.netbeans.modules.project.ui.actions.MainProjectAction$2]” daemon [_thread_blocked, id=4464, stack(0x56f50000,0x57150000)]
0x4fe30400 JavaThread “Inactive RequestProcessor thread [Was:JarFs - modification watcher/org.openide.filesystems.JarFileSystem$2]” daemon [_thread_blocked, id=5756, stack(0x56950000,0x56b50000)]
0x4fe35c00 JavaThread “Inactive RequestProcessor thread [Was:AnnotationHolder/org.netbeans.modules.editor.hints.AnnotationHolder$4$2]” daemon [_thread_blocked, id=5312, stack(0x563e0000,0x565e0000)]
0x4fe36400 JavaThread “Inactive RequestProcessor thread [Was:Flush UI Logs/org.netbeans.modules.uihandler.UIHandler$2WriteOut]” daemon [_thread_blocked, id=3852, stack(0x546f0000,0x548f0000)]
0x5bb96800 JavaThread “Swing-Shell” daemon [_thread_blocked, id=5668, stack(0x5c700000,0x5c900000)]
0x5bb96000 JavaThread “Timer-0” daemon [_thread_blocked, id=5832, stack(0x5c430000,0x5c630000)]
0x4fe33c00 JavaThread “DestroyJavaVM” [_thread_blocked, id=4036, stack(0x02430000,0x02630000)]
0x4fe33000 JavaThread “TimerQueue” daemon [_thread_blocked, id=2056, stack(0x57dd0000,0x57fd0000)]
0x4fe32c00 JavaThread “Worker-JM” [_thread_blocked, id=4616, stack(0x57b10000,0x57d10000)]
0x4fe32400 JavaThread “Framework Event Dispatcher” daemon [_thread_blocked, id=508, stack(0x57910000,0x57b10000)]
0x4fe31c00 JavaThread “Thread-3” daemon [_thread_blocked, id=5352, stack(0x576f0000,0x578f0000)]
0x4fe31800 JavaThread “W32 File Monitor” daemon [_thread_in_native, id=2280, stack(0x574a0000,0x576a0000)]
0x4fe31000 JavaThread “File Watcher” daemon [_thread_blocked, id=5608, stack(0x57260000,0x57460000)]
0x4fe2f800 JavaThread “Editor Parsing Loop (201310111528)” daemon [_thread_blocked, id=4384, stack(0x56690000,0x56890000)]
0x555a0000 JavaThread “State Data Manager” daemon [_thread_blocked, id=4072, stack(0x561c0000,0x563c0000)]
0x5558a800 JavaThread “Framework Active Thread” [_thread_blocked, id=4904, stack(0x55e20000,0x56020000)]
0x4fdbc000 JavaThread “AWT-EventQueue-0” [_thread_blocked, id=5924, stack(0x53f60000,0x54160000)]
0x4fdb1800 JavaThread “AWT-Windows” daemon [_thread_in_native, id=6088, stack(0x53cf0000,0x53ef0000)]
0x4fdb1400 JavaThread “AWT-Shutdown” [_thread_blocked, id=5240, stack(0x53a40000,0x53c40000)]
0x4e87ac00 JavaThread “Java2D Disposer” daemon [_thread_blocked, id=5200, stack(0x537f0000,0x539f0000)]
0x4fcf7c00 JavaThread “RequestProcessor queue manager” daemon [_thread_blocked, id=5504, stack(0x53430000,0x53630000)]
0x4fcbe800 JavaThread “CLI Requests Server” daemon [_thread_in_native, id=2808, stack(0x527f0000,0x529f0000)]
0x4e80f400 JavaThread “Active Reference Queue Daemon” daemon [_thread_blocked, id=5992, stack(0x50250000,0x50450000)]
0x4e6d5000 JavaThread “Service Thread” daemon [_thread_blocked, id=5268, stack(0x4f650000,0x4f850000)]
0x4e6cb800 JavaThread “C1 CompilerThread0” daemon [_thread_blocked, id=5920, stack(0x4ee40000,0x4ee90000)]
0x4e6ca400 JavaThread “Attach Listener” daemon [_thread_blocked, id=3324, stack(0x4f410000,0x4f610000)]
0x4e6c7000 JavaThread “Signal Dispatcher” daemon [_thread_blocked, id=2732, stack(0x4f160000,0x4f360000)]
0x4e699c00 JavaThread “Finalizer” daemon [_thread_blocked, id=740, stack(0x4ef50000,0x4f150000)]
0x4e692800 JavaThread “Reference Handler” daemon [_thread_blocked, id=2124, stack(0x4eba0000,0x4eda0000)]
Other Threads:
0x4e691000 VMThread [stack: 0x4e910000,0x4e960000] [id=5996]
0x4e6ef000 WatcherThread [stack: 0x4f360000,0x4f3b0000] [id=3220]
VM state:at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x0043d3b0] Threads_lock - owner thread: 0x4e691000
[0x0043d7c0] Heap_lock - owner thread: 0x4fdbc000
Heap
def new generation total 53248K, used 32905K [0x04630000, 0x07ff0000, 0x14630000)
eden space 47360K, 64% used [0x04630000, 0x063f2990, 0x07470000)
from space 5888K, 41% used [0x07a30000, 0x07c8fa70, 0x07ff0000)
to space 5888K, 0% used [0x07470000, 0x07470000, 0x07a30000)
tenured generation total 118216K, used 70928K [0x14630000, 0x1b9a2000, 0x34630000)
the space 118216K, 59% used [0x14630000, 0x18b740a0, 0x18b74200, 0x1b9a2000)
compacting perm gen total 57344K, used 57343K [0x34630000, 0x37e30000, 0x4c630000)
the space 57344K, 99% used [0x34630000, 0x37e2ffa0, 0x37e30000, 0x37e30000)
No shared spaces configured.
Card table byte_map: [0x4e430000,0x4e680000] byte_map_base: 0x4e40ce80
Polling page: 0x000c0000
Code Cache [0x02630000, 0x02ee0000, 0x04630000)
total_blobs=4927 nmethods=4610 adapters=251 free_code_cache=23913Kb largest_free_block=24477440
Compilation events (10 events):
Event: 532.813 Thread 0x4e6cb800 4749 % com.jidesoft.utils.Lm::a @ 197 (481 bytes)
Event: 532.814 Thread 0x4e6cb800 nmethod 4749% 0x02ed32c8 code [0x02ed3530, 0x02ed477c]
Event: 532.845 Thread 0x4e6cb800 4751 java.util.zip.Inflater::finalize (5 bytes)
Event: 532.845 Thread 0x4e6cb800 nmethod 4751 0x02e63248 code [0x02e63340, 0x02e633cc]
Event: 532.868 Thread 0x4e6cb800 4752 com.jidesoft.utils.Lm::c (51 bytes)
Event: 532.869 Thread 0x4e6cb800 nmethod 4752 0x02ed63c8 code [0x02ed64e0, 0x02ed665c]
Event: 532.879 Thread 0x4e6cb800 4753 java.util.Collections$SynchronizedMap:: (42 bytes)
Event: 532.879 Thread 0x4e6cb800 nmethod 4753 0x02ed6888 code [0x02ed6990, 0x02ed6acc]
Event: 533.084 Thread 0x4e6cb800 4754 s java.lang.Throwable::getOurStackTrace (80 bytes)
Event: 533.084 Thread 0x4e6cb800 nmethod 4754 0x02ed6b48 code [0x02ed6c70, 0x02ed7038]
GC Heap History (10 events):
Event: 526.120 GC heap before
{Heap before GC invocations=78 (full 6):
def new generation total 48256K, used 44409K [0x04630000, 0x07a80000, 0x14630000)
eden space 42944K, 100% used [0x04630000, 0x07020000, 0x07020000)
from space 5312K, 27% used [0x07550000, 0x076be7a0, 0x07a80000)
to space 5312K, 0% used [0x07020000, 0x07020000, 0x07550000)
tenured generation total 107088K, used 87926K [0x14630000, 0x1aec4000, 0x34630000)
the space 107088K, 82% used [0x14630000, 0x19c0da60, 0x19c0dc00, 0x1aec4000)
compacting perm gen total 52992K, used 52836K [0x34630000, 0x379f0000, 0x4c630000)
the space 52992K, 99% used [0x34630000, 0x379c93d8, 0x379c9400, 0x379f0000)
Event: 526.131 GC heap after
Heap after GC invocations=79 (full 6):
def new generation total 48256K, used 2741K [0x04630000, 0x07a80000, 0x14630000)
eden space 42944K, 0% used [0x04630000, 0x04630000, 0x07020000)
from space 5312K, 51% used [0x07020000, 0x072cd750, 0x07550000)
to space 5312K, 0% used [0x07550000, 0x07550000, 0x07a80000)
Event: 526.261 GC heap before
{Heap before GC invocations=79 (full 6):
def new generation total 48256K, used 38329K [0x04630000, 0x07a80000, 0x14630000)
eden space 42944K, 82% used [0x04630000, 0x068f0ec8, 0x07020000)
compacting perm gen total 53248K, used 53243K [0x34630000, 0x37a30000, 0x4c630000)
the space 53248K, 99% used [0x34630000, 0x37a2efb0, 0x37a2f000, 0x37a30000)
Event: 526.469 GC heap after
Heap after GC invocations=80 (full 7):
def new generation total 53248K, used 0K [0x04630000, 0x07ff0000, 0x14630000)
eden space 47360K, 0% used [0x04630000, 0x04630000, 0x07470000)
from space 5888K, 0% used [0x07470000, 0x07470000, 0x07a30000)
to space 5888K, 0% used [0x07a30000, 0x07a30000, 0x07ff0000)
Event: 532.788 GC heap before
{Heap before GC invocations=80 (full 7):
def new generation total 53248K, used 47360K [0x04630000, 0x07ff0000, 0x14630000)
eden space 47360K, 100% used [0x04630000, 0x07470000, 0x07470000)
compacting perm gen total 54528K, used 54291K [0x34630000, 0x37b70000, 0x4c630000)
the space 54528K, 99% used [0x34630000, 0x37b34f98, 0x37b35000, 0x37b70000)
Event: 532.802 GC heap after
Heap after GC invocations=81 (full 7):
def new generation total 53248K, used 2875K [0x04630000, 0x07ff0000, 0x14630000)
from space 5888K, 48% used [0x07a30000, 0x07cfefb8, 0x07ff0000)
Event: 532.837 GC heap before
{Heap before GC invocations=81 (full 7):
def new generation total 53248K, used 50235K [0x04630000, 0x07ff0000, 0x14630000)
Event: 532.843 GC heap after
Heap after GC invocations=82 (full 7):
def new generation total 53248K, used 2695K [0x04630000, 0x07ff0000, 0x14630000)
from space 5888K, 45% used [0x07470000, 0x07711f80, 0x07a30000)
Event: 532.897 GC heap before
{Heap before GC invocations=82 (full 7):
def new generation total 53248K, used 50055K [0x04630000, 0x07ff0000, 0x14630000)
compacting perm gen total 54528K, used 54358K [0x34630000, 0x37b70000, 0x4c630000)
the space 54528K, 99% used [0x34630000, 0x37b45928, 0x37b45a00, 0x37b70000)
Event: 532.904 GC heap after
Heap after GC invocations=83 (full 7):
def new generation total 53248K, used 2430K [0x04630000, 0x07ff0000, 0x14630000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 533.098 Thread 0x4fdbc000 Threw 0x05758990 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.098 Thread 0x4fdbc000 Threw 0x0575b068 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.102 Thread 0x4fdbc000 Threw 0x0589e7b8 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.102 Thread 0x4fdbc000 Threw 0x058a14f0 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.106 Thread 0x4fdbc000 Threw 0x058e15f8 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.106 Thread 0x4fdbc000 Threw 0x058e3fa8 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.108 Thread 0x4fdbc000 Threw 0x0591e108 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.109 Thread 0x4fdbc000 Threw 0x05920948 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.111 Thread 0x4fdbc000 Threw 0x05a970c0 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 533.111 Thread 0x4fdbc000 Threw 0x05a99798 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244
Events (10 events):
Event: 533.102 loading class 0x5b7480b0
Event: 533.102 loading class 0x5b7480b0 done
Event: 533.106 loading class 0x5b748150
Event: 533.106 loading class 0x5b748150 done
Event: 533.108 loading class 0x5b74aa80
Event: 533.108 loading class 0x5b74aa80 done
Event: 533.109 Executing VM operation: RevokeBias
Event: 533.109 Executing VM operation: RevokeBias done
Event: 533.111 loading class 0x5b74abe8
Event: 533.111 loading class 0x5b74abe8 done
Dynamic libraries:
0x01000000 - 0x0102f000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\javaw.exe
0x77c60000 - 0x77de0000 C:\Windows\SysWOW64\ntdll.dll
0x757f0000 - 0x75900000 C:\Windows\syswow64\kernel32.dll
0x75ac0000 - 0x75b07000 C:\Windows\syswow64\KERNELBASE.dll
0x762b0000 - 0x76350000 C:\Windows\syswow64\ADVAPI32.dll
0x766a0000 - 0x7674c000 C:\Windows\syswow64\msvcrt.dll
0x75900000 - 0x75919000 C:\Windows\SysWOW64\sechost.dll
0x76780000 - 0x76870000 C:\Windows\syswow64\RPCRT4.dll
0x75680000 - 0x756e0000 C:\Windows\syswow64\SspiCli.dll
0x75670000 - 0x7567c000 C:\Windows\syswow64\CRYPTBASE.dll
0x756e0000 - 0x757e0000 C:\Windows\syswow64\USER32.dll
0x75b10000 - 0x75ba0000 C:\Windows\syswow64\GDI32.dll
0x76530000 - 0x7653a000 C:\Windows\syswow64\LPK.dll
0x75ca0000 - 0x75d3d000 C:\Windows\syswow64\USP10.dll
0x71e50000 - 0x71fee000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
0x75a40000 - 0x75a97000 C:\Windows\syswow64\SHLWAPI.dll
0x75940000 - 0x759a0000 C:\Windows\system32\IMM32.DLL
0x75bd0000 - 0x75c9c000 C:\Windows\syswow64\MSCTF.dll
0x71360000 - 0x7141f000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\msvcr100.dll
0x62040000 - 0x623c0000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\client\jvm.dll
0x754f0000 - 0x754f7000 C:\Windows\system32\WSOCK32.dll
0x774d0000 - 0x77505000 C:\Windows\syswow64\WS2_32.dll
0x759a0000 - 0x759a6000 C:\Windows\syswow64\NSI.dll
0x71c80000 - 0x71cb2000 C:\Windows\system32\WINMM.dll
0x75930000 - 0x75935000 C:\Windows\syswow64\PSAPI.DLL
0x71350000 - 0x7135c000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\verify.dll
0x6b540000 - 0x6b560000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\java.dll
0x6b520000 - 0x6b533000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\zip.dll
0x6b500000 - 0x6b514000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\net.dll
0x72960000 - 0x7299c000 C:\Windows\system32\mswsock.dll
0x72940000 - 0x72946000 C:\Windows\System32\wship6.dll
0x71340000 - 0x7134f000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\nio.dll
0x75250000 - 0x7526c000 C:\Windows\system32\IPHLPAPI.DLL
0x75240000 - 0x75247000 C:\Windows\system32\WINNSI.DLL
0x72d10000 - 0x72d1d000 C:\Windows\system32\dhcpcsvc6.DLL
0x72cf0000 - 0x72d02000 C:\Windows\system32\dhcpcsvc.DLL
0x61da0000 - 0x61ee3000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\awt.dll
0x75d50000 - 0x75ddf000 C:\Windows\syswow64\OLEAUT32.dll
0x76540000 - 0x7669c000 C:\Windows\syswow64\ole32.dll
0x74dd0000 - 0x74de6000 C:\Windows\system32\CRYPTSP.dll
0x74d90000 - 0x74dcb000 C:\Windows\system32\rsaenh.dll
0x729b0000 - 0x729c7000 C:\Windows\system32\USERENV.dll
0x729a0000 - 0x729ab000 C:\Windows\system32\profapi.dll
0x72a40000 - 0x72a50000 C:\Windows\system32\NLAapi.dll
0x728d0000 - 0x728e0000 C:\Windows\system32\napinsp.dll
0x728b0000 - 0x728c2000 C:\Windows\system32\pnrpnsp.dll
0x72860000 - 0x728a4000 C:\Windows\system32\DNSAPI.dll
0x72850000 - 0x72858000 C:\Windows\System32\winrnr.dll
0x72820000 - 0x72847000 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x72950000 - 0x72955000 C:\Windows\System32\wshtcpip.dll
0x72810000 - 0x72816000 C:\Windows\system32\rasadhlp.dll
0x727d0000 - 0x72808000 C:\Windows\System32\fwpuclnt.dll
0x71c60000 - 0x71c73000 C:\Windows\system32\DWMAPI.DLL
0x6b4c0000 - 0x6b4f5000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\splashscreen.dll
0x71a20000 - 0x71aa0000 C:\Windows\system32\uxtheme.dll
0x6f460000 - 0x6f47a000 C:\Program Files (x86)\TeamViewer\Version9\tv_w32.dll
0x754e0000 - 0x754e9000 C:\Windows\system32\VERSION.dll
0x76870000 - 0x774ba000 C:\Windows\syswow64\SHELL32.dll
0x62000000 - 0x62038000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\fontmanager.dll
0x759b0000 - 0x75a33000 C:\Windows\syswow64\CLBCatQ.DLL
0x6b490000 - 0x6b4c0000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\t2k.dll
0x56020000 - 0x56092000 C:\Program Files (x86)\NetBeans 7.4\platform\modules\lib\x86\jnidispatch-340.dll
0x6afd0000 - 0x6afda000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\management.dll
0x75180000 - 0x751d8000 C:\Windows\system32\winhttp.dll
0x75130000 - 0x7517f000 C:\Windows\system32\webio.dll
0x726b0000 - 0x726b8000 C:\Windows\system32\credssp.dll
0x75ba0000 - 0x75bc7000 C:\Windows\syswow64\CFGMGR32.dll
0x72030000 - 0x720b4000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18201_none_ec80f00e8593ece5\comctl32.dll
0x714c0000 - 0x715f0000 C:\Windows\system32\WindowsCodecs.dll
0x750c0000 - 0x7510c000 C:\Windows\system32\apphelp.dll
0x63450000 - 0x63481000 C:\Windows\system32\EhStorShell.dll
0x776c0000 - 0x7785d000 C:\Windows\syswow64\SETUPAPI.dll
0x776a0000 - 0x776b2000 C:\Windows\syswow64\DEVOBJ.dll
0x74c90000 - 0x74d85000 C:\Windows\system32\PROPSYS.dll
0x62c30000 - 0x6303a000 C:\PROGRA~2\MICROS~2\Office14\GROOVEEX.DLL
0x72390000 - 0x72433000 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCR90.dll
0x74830000 - 0x748be000 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCP90.dll
0x634a0000 - 0x634cb000 C:\Windows\WinSxS\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b\ATL90.DLL
0x63040000 - 0x6344f000 C:\PROGRA~2\COMMON~1\MICROS~1\OFFICE14\Cultures\office.odf
0x623c0000 - 0x62c24000 C:\PROGRA~2\MICROS~2\Office14\1033\GrooveIntlResource.dll
0x63700000 - 0x63770000 C:\Windows\system32\ntshrui.dll
0x72de0000 - 0x72df9000 C:\Windows\system32\srvcli.dll
0x74390000 - 0x7439b000 C:\Windows\system32\cscapi.dll
0x6f530000 - 0x6f53a000 C:\Windows\system32\slc.dll
0x61fd0000 - 0x61ff4000 C:\Program Files (x86)\Java\jdk1.7.0_45\jre\bin\dcpr.dll
0x61f60000 - 0x61fc9000 C:\Windows\System32\msvcp100.dll
0x71250000 - 0x7133b000 C:\Windows\System32\dbghelp.dll
0x75de0000 - 0x75f00000 C:\Windows\syswow64\Crypt32.dll
0x75d40000 - 0x75d4c000 C:\Windows\syswow64\MSASN1.dll
0x72780000 - 0x72783000 C:\Windows\system32\Security.dll
0x74c60000 - 0x74c81000 C:\Windows\system32\ntmarta.dll
0x77620000 - 0x77665000 C:\Windows\syswow64\WLDAP32.dll
0x61a60000 - 0x61bf8000 C:\Windows\system32\NetworkExplorer.dll
0x61f00000 - 0x61f2f000 C:\Windows\System32\shdocvw.dll
0x71a00000 - 0x71a12000 C:\Windows\system32\MPR.dll
0x74360000 - 0x74368000 C:\Windows\System32\drprov.dll
0x72e30000 - 0x72e59000 C:\Windows\System32\WINSTA.dll
0x74340000 - 0x74354000 C:\Windows\System32\ntlanman.dll
0x73ae0000 - 0x73af7000 C:\Windows\System32\davclnt.dll
0x743a0000 - 0x743a8000 C:\Windows\System32\DAVHLPR.dll
0x72dd0000 - 0x72ddf000 C:\Windows\system32\wkscli.dll
0x72e00000 - 0x72e09000 C:\Windows\system32\netutils.dll
0x61f30000 - 0x61f52000 C:\Windows\system32\EhStorAPI.dll
0x76750000 - 0x7677e000 C:\Windows\syswow64\WINTRUST.dll
0x714b0000 - 0x714b9000 C:\Windows\system32\LINKINFO.dll
0x73520000 - 0x73528000 C:\Windows\system32\Secur32.dll
0x72550000 - 0x7255f000 C:\Windows\system32\samcli.dll
0x74210000 - 0x74222000 C:\Windows\system32\SAMLIB.dll
0x61cd0000 - 0x61d98000 C:\Windows\system32\OPENGL32.DLL
0x61ca0000 - 0x61cc2000 C:\Windows\system32\GLU32.dll
0x74240000 - 0x74327000 C:\Windows\system32\DDRAW.dll
0x74330000 - 0x74336000 C:\Windows\system32\DCIMAN32.dll
0x61c80000 - 0x61c95000 C:\Windows\system32\atiglpxx.dll
0x5d8d0000 - 0x5ee5f000 C:\Windows\system32\atioglxx.dll
0x61980000 - 0x61a59000 C:\Windows\system32\atiadlxy.dll
0x72e60000 - 0x72e6d000 C:\Windows\system32\WTSAPI32.dll
0x71140000 - 0x71250000 C:\Windows\system32\aticfx32.dll
0x61c40000 - 0x61c5c000 C:\Windows\system32\atigktxx.dll
VM Arguments:
jvm_args: -Dnetbeans.importclass=org.netbeans.upgrade.AutoUpgrade -Dnetbeans.accept_license_class=org.netbeans.license.AcceptLicense -Xss2m -Xms32m -XX:PermSize=32m -Dapple.laf.useScreenMenuBar=true -Dapple.awt.graphics.UseQuartz=true -Dsun.java2d.noddraw=true -Dsun.java2d.dpiaware=true -Dsun.zip.disableMemoryMapping=true -Xmx768m -XX:MaxPermSize=384m -Djdk.home=C:\Program Files (x86)\Java\jdk1.7.0_45 -Dnetbeans.home=C:\Program Files (x86)\NetBeans 7.4\platform -Dnetbeans.user=C:\Users\Niels\AppData\Roaming\NetBeans\7.4 -Dnetbeans.default_userdir_root=C:\Users\Niels\AppData\Roaming\NetBeans -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=C:\Users\Niels\AppData\Roaming\NetBeans\7.4\var\log\heapdump.hprof -Dsun.awt.keepWorkingSetOnMinimize=true -Dnetbeans.dirs=C:\Program Files (x86)\NetBeans 7.4\nb;C:\Program Files (x86)\NetBeans 7.4\ergonomics;C:\Program Files (x86)\NetBeans 7.4\ide;C:\Program Files (x86)\NetBeans 7.4\extide;C:\Program Files (x86)\NetBeans 7.4\java;C:\Program Files (x86)\NetBeans 7.4\apisupport;C:\Program Files (x86)\NetBeans 7.4\webcommon;C:\Program Files (x86)\NetBeans 7.4\websvccommon;C:\Program Files (x86)\NetBeans 7.4\enterprise;C:\Program Files (x86)\NetBeans 7.4\mobility;C:\Program Files (x86)\NetBeans 7.4\profiler;C:\Program Files (x86)\NetBeans 7.4\python;C:\Program Files (x86)\NetBeans 7.4\php;C:\Program Files (x86)\NetBeans 7.4\identity;C:\Program Files (x86)\NetBeans 7.4\harness;C:\Program Files (x86)\NetBeans 7.4\cnd;C:\Program Files (x86)\NetBeans 7.4\dlight;C:\Program Files (x86)\NetBeans 7.4\groovy;C:\Program Files (x86)\NetBeans 7.4\extra;C:\Program Files (x86)\NetBeans 7.4\javacard;C:\Program Files (x86)\NetBeans 7.4\javafx
java_command: org/netbeans/Main --branding nb --cachedir C:\Users\Niels\AppData\Local\NetBeans\Cache/7.4
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\MySQL\MySQL Utilities 1.3.5
USERNAME=Niels
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 58 stepping 9, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, aes, erms, tsc, tscinvbit, tscinv
Memory: 4k page, physical 8280084k(4077836k free), swap 16558304k(11565724k free)
vm_info: Java HotSpot™ Client VM (24.45-b08) for windows-x86 JRE (1.7.0_45-b18), built on Oct 8 2013 06:02:43 by “java_re” with unknown MS VC++:1600
time: Tue Feb 25 17:26:57 2014
elapsed time: 533 seconds
I hope someone can help me because I really need VP on my NetBeans.
Thanks!
