hy
i genrate code by sde but it’s doesn’t work with asp.net application in visual studio 2005
thanks for your help
hy
Hi bentata,
Could you provide more information about your problem? Thank you.
Best Regards,
The code generated from the ORM diagram did work but I found the sample code generated tricky to get working. The display function worked OK (I think) but the other samples didn’t quite work so well.
A bit of surfing turned up this article (from the Visual Paradigm site). The article is great and works with no problems.
Cheers
Q
