No license key found
Recently I’ve been evaluating VP (very nice software) and when I saw the Teamwork Server I decided to give that a try as well, but unfortunately no matter how many times I try to import the evaluation license file or reinstall the program (both installer, non-installer and on both windows and linux), the setup returns an error saying “No license key found. Teamwork Server will not work without a valid license key”.
I checked the vp.log that you guys mentioned in response to other problems and it contains the following:
Teamwork Server: 2.2 (sp1_20060314b)
[Fatal Error] :-1:-1: Premature end of file.
v.fpa: Parse error
	at v.uub.i(:334)
	at v.uub.f(:271)
	at v.wzl.i(:161)
	at v.wzl.i(:144)
	at v.be.f(:240)
	at v.be.i(:138)
	at v.mlz.<init>(:44)
	at v.mlz.<clinit>(:12)
	at v.xox.<init>(:258)
	at v.dmv.<init>(:311)
	at v.dmv.i(:148)
	at TeamworkServer.main(:33)
	at p.pi.i(:16)
	at com.vp.platform.installer.teamwork.StartServerMain.main(:11)
	at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
	at com.exe4j.runtime.WinLauncher.main(Unknown Source)
Caused by: org.xml.sax.SAXParseException: Premature end of file.
	at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown Source)
	at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unknown Source)
	at v.wip.parse(:23)
	at v.uub.i(:326)
	... 23 more
CLASS name org.mortbay.jetty.Server
17:33:14.312 EVENT  Statistics on = false for org.mortbay.jetty.Server@1815338
n is org.mortbay.http.SocketListener
17:33:14.375 EVENT  Checking Resource aliases
addWebApplications(..): C:\Documents and Settings\Administrator\Local Settings\Temp\vphttp19300/webapps/
can return: WebApplicationContext[/,file:/C:/Documents and Settings/Administrator/Local Settings/Temp/vphttp19300/webapps/root/]
n is [Lorg.mortbay.jetty.servlet.WebApplicationContext;
17:33:14.453 EVENT  Starting Jetty/4.2.x
17:33:14.703 EVENT  Started WebApplicationContext[/,Root WebApp]
17:33:15.437 EVENT  Started SocketListener on 0.0.0.0:1999
17:33:15.468 EVENT  Started org.mortbay.jetty.Server@1815338
I hope you can help me out, this software suits exactly what I need to do.
James
Hi user,
Thank you for the post.
It seems that there are some problems with the key file. Could you please send me for checking? You can send to my email address:
jick@visual-paradigm.com
Besides, please also try the steps below.
  1. Shutdown the server
  2. Put the key to the bin directory of Teamwork Server
  3. Restart the server
and see if it works.
Best Regards,
