Hi, I’ve just downloaded Visual Paradigm 16.3, Community Edition. I wanted to create a simple class diagram - but the class names don’t show up.
Even if I use a template diagram - methods and fields show up, but not the class names:
The class definitely has a name:
Similar issues are in sequence and activity diagrams (in activities the activity body is also not visible). All diagram elements seem correct - just the names (and activity bodies) don’t show up. The only place they are visible - is the diagram selection ribbon.
I’m running the newest VP CE version on Windows 10.
Thank you for your post. Unfortunately, we are unable to repeat the problem. Would you mind giving us your .vpp project file to have a check? You can upload the file to the following place. Only Visual Paradigm staff can access your files.
Sorry but we are unable to repeat the problem. Would you mind sending me the log file to have a look? You can export it from the About window (from the Help > About menu). By the way, did you change to start Visual Paradigm with another JVM?
Could you try to restart Visual Paradigm with a new workspace and see if it will work? To do this, select Help > Switch Workspace from the main menu. Select another folder and click OK.
If this solves the problem, would you mind sending me your original workspace folder for checking?
Would you please create a sample project which can repeat this problem and send us for diagnosis? You can send it to support@visual-paradigm.com. Thanks and look forward to hearing from you.
Thanks and we tested your project file it do works fine our our end. Would you please send me a screenshot of Window > Project Options > Diagramming > Shape to have a look? Look forward to hearing from you.
