Hello sir
i m having one another problem. actually what happens, after reverse process, class diagram creates but there is No multiplicity showing. it shows the relationship also. but no Multiplicity.
In the help file, multiplicilty is also showing???/ how come it is possible???/ can u give me ur valuable suggestion on this topic? i m waiting for ur responce?.
First, I am going to remove another 2 messages from you which talks about the same issue. In order for us to provide a better solution and followup work, I hope you could create one post for one issue.
For the missing multiplicity issue, is there any source for us to repeat the problem? I tried reversing some DLLs and couldn’t repeat the problem you have.
hello sir,
cos i m working in a company and this is the part of one project’s. that’s why i couldn’t send u the Dll or Exe file. if u can suggest me indirectly, pls do it.
i m having lots of pressure for this work. pls sir
I understand your difficulties. How about some sample code for repducing the problem? You need not to send us your original code. Any sample code would be fine.
I am unable to reverse your exe file, it warned ‘The DLL/exe is not a .NET compatible’. Are you sure the project can reproduce the problem of missing multiplicity? Thank you.
Since the meeting info is considered as sensitive information, so I am unable to post it in the forum. Therefore, I will try resend you the email later today. I hope you will receive it.
hello sir,
as u said, cos of sensitive information i cant send it to the forum, but i can send it in ur mail id… but still no message having answer, no link. can u pls send it again on my mail id.
