It would be convenient when VP automatically selects context API diagram, when one want generate yaml. Manual selection is problematic especially in big project
Hi Robert,
Thank you for your inquiry. I have forwarded your post to our team to study. When there is any news, I will let you know.
Hi Robert,
Please try to right click on the diagram, and then select to generate through the popup menu. This will select only the active diagram in the tree.
unfortunately the same behaviour
Hi Robert,
I have captured a video to show you the steps and the result I obtained. In the video, I created two class diagrams. In the end, only the active diagram is being selected. Could you check if my steps are the same as yours?
not working, maybe more complex example - organized with Models structure, like sub folders.
Hi Robert,
Thank you for your reply. Are you able to repeat the problem with a new project? If yes, could you send me the project for checking? You can upload it to our repository here:
URL: ownCloud
Password: kb5jsdf09gfn
Note: Only staff from Visual Paradigm can access your file.
