I would like to compare two projects. Because there is no such tool built to VP, I would like to open project in two windows in two instance of VP. But there is another problem: to open two instance of VP on the same computer I need two floating licens keys. Is there any possibility to open two instance of VP using one license key??
Hi adikowo,
Thank you for your post. You can start at most one instance with 1 license. For your case, I suggest you run the second instance in Viewer Edition. With the Viewer Edition, you can view all your diagrams without needing a separate license.
Please install another instance of VP, set it as Viewer Edition, run it and open the project file to browse it.
