In DBVA, after update my db and code, I got an orm.PersistentException with message Failed to create ThreadBaseSessionController??
Here the full exception report:
orm.PersistentException: Failed to create ThreadBaseSessionController
at orm.util.ThreadBaseSessionController.(ThreadBaseSessionController.java:29)
at orm.PersistentManager.(PersistentManager.java:62)
at org.mypackage.MyProjectPersistentManager.(MyProjectPersistentManager.java:21)
at org.mypackage.MyProjectPersistentManager.instance(MyProjectPersistentManager.java:30)
at org.mypackage.Sample.main(Sample.java:460)
From the trace we cannot find out the cause of the problem, do you mind sending me your project, or any sample project that we can repeat the problem? My email address is antony@visual-paradigm.com
Can you send me the complete stack trace on your problem? or if possible, could you send me the vp.log file? You can locate the log file in the %VP Suite%/bin directory.
Thanks in advance!
Our engineers discover that the PK and FK definition was not matched in your model. This could be the reason why the generated codes not work. Please modify your model and regenerate the persistent code and try again. If you have any further questions, please feel free to contact me again.
hi i have the same problem. A failed to create ThreadBaseSessionController Exception in my stack trace says it’s caused by a property-ref not found. If you can help i’d realliy apreciatte.
thnx.
Kyroz
this is my stack trace:
at orm.PersistentManager.(PersistentManager.java:66)
at cl.sinaptica.model.Modelling2PersistentManager.(Modelling2PersistentManager.java:21)
at cl.sinaptica.model.Modelling2PersistentManager.instance(Modelling2PersistentManager.java:31)
at Sample.dispose(Sample.java:102)
at Sample.main(Sample.java:116)
Caused by: org.hibernate.MappingException: property-ref not found: PerfilIdPerfil in class: cl.sinaptica.model.Usuario
at org.hibernate.cfg.Configuration.secondPassCompile(Configuration.java:887)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1049)
at orm.util.ORMSessionFactory.(ORMSessionFactory.java:17)
at orm.util.ThreadBaseSessionController.(ThreadBaseSessionController.java:26)
I have the same problem mentioned above regarding the ThreadBaseSessionController with missing hibernate mappings/ “property-ref not found”. My exception stack is identical with respect to my project’s classes.
This is a shame as I was very pleased with DB Architect v3.0 (Windows) so far in an evaluation license. The software seemed to work fine for the first project I generated, and I was actively pleading the case to purchase this tool with my management. However, with my second test project failing, I doubt I will purchase.
Are you using the latest release? As I know our engineers have recently fixed a bug which is likely to be the cause of the problem you encountered. If you are not using the latest release, I would recommend you advance to the latest one and try again.
If the problem still persists, could you please send me your project file and the steps for reproducing the same problem ? Thank you.
Finally, if you require an extension to your evaluation period, please let me know.
org.orm.PersistentException: Failed to create ThreadBaseSessionController
at org.orm.util.ThreadBaseSessionController.(ThreadBaseSessionController.java:29)
at org.orm.PersistentManager.(PersistentManager.java:90)
at be.tradelec.autopermit.UntitledPersistentManager.(UntitledPersistentManager.java:30)
at be.tradelec.autopermit.UntitledPersistentManager.instance(UntitledPersistentManager.java:40)
at ormsamples.CreateUntitledData.main(CreateUntitledData.java:145)
Caused by: org.hibernate.MappingException: Foreign key (FKBB979BF4612C5064:address [street_idStreet])) must have same number of columns as the referenced primary key (street [idStreet,name])
at org.hibernate.mapping.ForeignKey.alignColumns(ForeignKey.java:90)
at org.hibernate.mapping.ForeignKey.alignColumns(ForeignKey.java:73)
at org.hibernate.cfg.Configuration.secondPassCompileForeignKeys(Configuration.java:1263)
at org.hibernate.cfg.Configuration.secondPassCompile(Configuration.java:1170)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1286)
at org.orm.util.ORMSessionFactory.(ORMSessionFactory.java:17)
at org.orm.util.ThreadBaseSessionController.(ThreadBaseSessionController.java:26)
… 4 more
I can’t really understand why this error occurs because I’m not even trying to save something in the address table.
Perhaps if I could enable something to see the generated sql statement I can try to find the source of the problem.
When I try to reverse the DB via annotations + DAO with interface I get a different error:
org.hibernate.AnnotationException: referencedColumnNames(idlanguage) of be.tradelec.autopermit.Address_has_languagePK.id.language_idlanguage referencing be.tradelec.autopermit.Language not mapped to a single property
at org.hibernate.cfg.BinderHelper.createSyntheticPropertyReference(BinderHelper.java:167)
at org.hibernate.cfg.FkSecondPass.doSecondPass(FkSecondPass.java:63)
at org.hibernate.cfg.AnnotationConfiguration.processFkSecondPassInOrder(AnnotationConfiguration.java:477)
at org.hibernate.cfg.AnnotationConfiguration.secondPassCompile(AnnotationConfiguration.java:297)
at org.hibernate.cfg.Configuration.buildMappings(Configuration.java:1115)
at be.tradelec.autopermit.UntitledPersistentManager.createConfiguration(UntitledPersistentManager.java:95)
at org.orm.PersistentManager.(PersistentManager.java:59)
at be.tradelec.autopermit.UntitledPersistentManager.(UntitledPersistentManager.java:31)
at be.tradelec.autopermit.UntitledPersistentManager.instance(UntitledPersistentManager.java:105)
at ormsamples.CreateUntitledData.main(CreateUntitledData.java:184)
I will mail you my mysql database together with my VP-UML project + the generated code.
Thanks for the details and I received your email with workspace, project file and generated code already. I’ve forwarded the issue to our engineers to investigate, and I’ll come back to you once there is any feedback.
Our engineers checked that the problem is due to 2 problems. 1st problem
More than 10 relationships on your ERD has constraint error that FK table doesn’t have enough column to reference the source table (please see attached image as one of the problematic relationship). You need to fix the problem by specifying a column to reference the source table, or select Generate Default Column to let VP creates for you.
BTW, may I know how did you create these entities so that there are constraint error on relationships? Did you create entities manually, reverse database, or some other ways?
2nd problem
There is a bug in Annotation in Hibernate, which will be fixed in next release (VP Suite 4.1). I’ve sent you an email with the release candidate of VP Suite 4.1 so you can have a try to confirm it’s fixed.
If you cannot find my email, please try to find it from your trash and junk box.
Feel free to let me know if there is any further inquiry.
Orm.PersistentException: Failed to create ThreadBaseSessionController
at Orm.Util.UserDefinedSessionController…ctor(Configuration cfg)
at Orm.PersistentManager…ctor(DotNetConnectionSetting connectionSetting, SessionType sessionType)
I think I have this issue, however, if it’s related to 1st problem, then how could I know what exact relations are have problems?
Can you send me your project file to have a look? You can send to support-team@visual-paradigm.com in case you don’t want to attach it in here. But please make sure you include the URL of this post in your email. Thanks.
I have this error in one particular situation. When I have built the code and the database automatically, I want to use the code in a project that has different package name with the one defined in the process of making the code through the “Hibernate>Wizard” menu. But when I rename the imported package (in the new project), the error comes up. It happens because reference to the old package name is not only in class definition. There also also references in strings in “*.hbm.xml” files. When I refactor all of the references, including the ones in strings, the error does not happen anymore.
The hbm files reference the package, class, property names, so if you change these name after generate, you have to manually update the corresponding hbm files. It is recommended to change in VP and re-generate. You can also generate mapping as annotation without the hbm files.
