I was getting on well with the evaluation and had almost decided to buy the pro version until I tried to use it with a framework that consists of a large class hierarchy. Instant reverse worked fine and everything was great until I tried to save it…
Further investigation indicates it ran out of memory during the save- after allocating aver 500MB of virtual memory. Here is the bit from the log file:
saveGenericShapeInstance(…)v.qrd@129d744
java.lang.OutOfMemoryError
I can save small models - upto this point I had played with upto about 50 classes.
As a further bit of information there is obviously an exception thrown at startup too :
[Thu Dec 30 22:15:27 GMT 2004]: Start Visual Paradigm for UML Professional Edition [VP-UML PE]: 4.0 (20041218b)
java.io.IOException: CreateProcess: jdk\bin\java -Xms64m -Xmx512m -cp “”;c:\progra~1\vpsuit~1.0\.install4j\i4jruntime.jar;c:\progra~1\vpsuit~1.0\launcher…\lib\vpplatform.jar;c:\progra~1\vpsuit~1.0\launcher…\lib\winpack.jar;c:\progra~1\vpsuit~1.0\launcher…\lib\jhall.jar;c:\progra~1\vpsuit~1.0\launcher…\lib\jniwrap.jar;c:\progra~1\vpsuit~1.0\launcher…\lib\vpJavaHelp.jar;c:\progra~1\vpsuit~1.0\launcher…\lib\openapi.jar;"" RV jdk error=2
at java.lang.Win32Process.create(Native Method)
at java.lang.Win32Process.(Unknown Source)
at java.lang.Runtime.execInternal(Native Method)
at java.lang.Runtime.exec(Unknown Source)
at v.akg.i(:474)
at RV.main(:436)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
While I could increase the maximum memory allowed and also the physical memory on the PC that is not really an answer - VP-UML should not need to allocate massive amounts of memory to save the state that it is already maintaining!
Any solutions??
Pete
