Hi there
I use VP-UML 3 Professional Edition and I want to generate code from classes in a class diagram. This works fine until I try to make a package for this classes. I tried two different ways, both failed:
I name all classes in the diagram with the full path name like com.solarmax.newpackage.Class1, com.solarmax.newpackage.Class2 etc. When I then start the code checker, I get the messages “Invalid name of class” for every class.
I place a package model into the class diagram and name it “com.solarmax.newpackage”. Then I connect all the classes with containments to the package model. When I start code generation I get the message “Invalid package name” for all classes.
The working directory for the Code Engine is like c:/projects/vp-uml/src. I expect that the code engine creates sub-dirs com/solarmax/newpackage, but it doesn’t. I also create the directory structure manually and set the working directory for the Code Engine to c:/projects/vp-uml/src/com/solarmax/newpackage. This also fails.
Any advice?
Marco
