Jick,
I started to assign the various classes into packages so that rather than one big schema there are several, more modular schema and have run into a problem.
I create packages by diagram - I use the text field above the diagram to name it.
Where I have classes in other diagrams they are not included in the package. I check this by looking at the children of the package.
When I generate it does not include the associations. You can see from the diagram below that there should be a number of elements created because of the associations that have been created. If this diagram is not in a package or in the default package then these get generated, if the diagram is a package then they do not get generated.
I have done some digging and it would appear that in xsdclass.vm if you stick the code:
#foreach( $attribute in $class.xsdElementAttributeIterator() )
DEBUG:$attribute.getName()
#end
you see all the real attributes but not the ones that should be created by assoication.
If I remove the package then I see all the attributes including those that should be created because of the assocations.
If I add the code $class.t_importClassesCount() then I can see that there are 4 import classes - I am guessing that these should be generated as well…assuming that the roles defined in the assoication let them…
Am I going mad? or just not using assoications properly?
