Today I was trying Instant Reverse an source.
But it fails at the namespace charater in PHP 5.3 ‘’
PHP 5.2 is end of life, and namespaces are getting used more and more these days so I’m surprised VP-UML does not support this yet.
When will this be implemented?
Thank you for your message but it seems this is already fixed in our latest release. May I know what version and build number of the tool you are using? And can you try update to latest release and see is it working?
Hi, I noticed that instant reverse has a problem with parsing multiple implements that use namespaces.
This class declaration generates an error on the first ‘, \TYPO3’
Sorry about this issue and our engineers are checking about the multiple implements problem you experienced. I’ll keep you post once there are any update and please be patient.
Hi, sorry for the delay. I would like to let you know the fail to reverse PHP source code with multiple implements which using namespace problem had been fixed in the latest version 10.2. Please update the software to latest patch build (20131120ba or later). Details about update to latest patch can be found at
i have an error when i do the instant reverse, that said : error when analysis encountred “)” at line 55 column 29.
I checked the code source and i dont understand what this error is.
the code is functionnal.
i have the latest version of VP.
Please help.
