Use-cases already have a “Rank” input value that is helpful to sort the use-cases by stakeholder’s priority. Adding a “Risk” and a “Complexity” value will give us two new very helpful keys to sort uses-case. “Risk” is often used as a secondary key to sort use-cases.
The “Complexity” factor would be very helpful to enable one (possibly VP-UML itself) to estimate the development effort based on the “Use Case Points Method” (Both Use-case and Actors must have a “Complexity” factor for the Use Case Points Method to work).
Added one link to the “Use Case Points” estimation method:
http://www.codeproject.com/gen/design/usecasep.asp
Also, please don’t forget to make those enumeration values (“Rank”, “Risk” and “Complexity”) configurable like the requirement enumeration values are (i.e. “Rank” is not configurable in the current version).
ZartC
