I was able to run on FreeBSD with a fairly simple patch to the Visual_Paradigm script and the installation of a few java packages.
- With this setup I was creating and editing Sequence Diagrams without any problem.
- However when I tried to create or edit a Block Diagram the was an error
WD0002displayed. - I can export Block Diagrams to a PNG successfully
The warnings below occur either when exporting or when trying to edit a block diagram:
This was only there once:
[2021/01/22 12:44:36] [warning] java.lang.ExceptionInInitializerError
at com.teamdev.jxbrowser.chromium.internal.ipc.IPC.getDefault(SourceFile:88)
at com.teamdev.jxbrowser.chromium.BrowserContext.<init>(SourceFile:61)
at com.teamdev.jxbrowser.chromium.BrowserContext.<clinit>(SourceFile:29)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.RuntimeException: JxBrowser license check failed: No valid license found. jar:file:/usr/home/hsw/Visual_Paradigm_16.2/Application/lib/lib02.jar!/META-INF/teamdev.licenses - Unsupported OS: FreeBSD
There were several instances of this:
[2021/01/22 12:44:56] [warning] java.lang.NoClassDefFoundError: Could not initialize class com.teamdev.jxbrowser.chromium.BrowserContext
at v.brl.r.a(:278)
at v.avn.aa.<init>(:325)
at v.avn.ag.<init>(:822)
