Hi guys
Recently when I click on “Open Project” menu at Project tab (or even pressing ctrl+o), the Open Project dialog won’t show and the following log will be generated in log.txt file instead!
[2021/04/15 10:46:52] [message] Exception in thread "AWT-EventQueue-0"
[2021/04/15 10:46:52] [message] java.lang.IllegalArgumentException: illegal component position
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Container.addImpl(Container.java:1120)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Container.add(Container.java:489)
[2021/04/15 10:46:52] [message] at v.awd.bt.a(:693)
[2021/04/15 10:46:52] [message] at v.awd.bt.f(:415)
[2021/04/15 10:46:52] [message] at v.awd.bt.<init>(:396)
[2021/04/15 10:46:52] [message] at v.awd.bq.<init>(:294)
[2021/04/15 10:46:52] [message] at v.awd.ay.a(:1669)
[2021/04/15 10:46:52] [message] at v.awd.a.x(:528)
[2021/04/15 10:46:52] [message] at v.awd.a.e(:28)
[2021/04/15 10:46:52] [message] at v.awd.b.itemStateChanged(:463)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.AbstractButton.fireItemStateChanged(AbstractButton.java:1995)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.AbstractButton$Handler.itemStateChanged(AbstractButton.java:2315)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.DefaultButtonModel.fireItemStateChanged(DefaultButtonModel.java:458)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.JToggleButton$ToggleButtonModel.setSelected(JToggleButton.java:364)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.ButtonGroup.setSelected(ButtonGroup.java:168)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.JToggleButton$ToggleButtonModel.setSelected(JToggleButton.java:346)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.AbstractButton.setSelected(AbstractButton.java:341)
[2021/04/15 10:46:52] [message] at v.awd.a.b(:506)
[2021/04/15 10:46:52] [message] at v.awd.a.<init>(:381)
[2021/04/15 10:46:52] [message] at v.awd.aw.<init>(:1583)
[2021/04/15 10:46:52] [message] at v.awd.aw.a(:1552)
[2021/04/15 10:46:52] [message] at v.avd.acb.b(:9121)
[2021/04/15 10:46:52] [message] at v.avd.acb.y(:9101)
[2021/04/15 10:46:52] [message] at v.avd.os.b(:2753)
[2021/04/15 10:46:52] [message] at v.avd.aan.a(:6840)
[2021/04/15 10:46:52] [message] at v.dmx.fp.actionPerformed(:8676)
[2021/04/15 10:46:52] [message] at org.pushingpixels.flamingo.api.common.AbstractCommandButton.fireActionPerformed(AbstractCommandButton.java:616)
[2021/04/15 10:46:52] [message] at org.pushingpixels.flamingo.api.common.AbstractCommandButton$ActionHandler.actionPerformed(AbstractCommandButton.java:568)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:405)
[2021/04/15 10:46:52] [message] at org.pushingpixels.flamingo.api.common.model.ActionRepeatableButtonModel.setPressed(ActionRepeatableButtonModel.java:123)
[2021/04/15 10:46:52] [message] at org.pushingpixels.flamingo.internal.ui.common.BasicCommandButtonListener.mouseReleased(BasicCommandButtonListener.java:147)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:297)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Component.processMouseEvent(Component.java:6632)
[2021/04/15 10:46:52] [message] at java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3342)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Component.processEvent(Component.java:6397)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Container.processEvent(Container.java:2263)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5008)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Component.dispatchEvent(Component.java:4840)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2772)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
[2021/04/15 10:46:52] [message] at java.base/java.security.AccessController.doPrivileged(Native Method)
[2021/04/15 10:46:52] [message] at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
[2021/04/15 10:46:52] [message] at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
[2021/04/15 10:46:52] [message] at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
[2021/04/15 10:46:53] [warning] java.lang.IllegalArgumentException: illegal component position
at v.awd.bt.a(:693)
at v.awd.bt.a(:343)
at v.awd.cg.a(:607)
at v.awd.cg.a(:602)
at v.bwc.ag.run(:25)
at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:313)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740)
I also tried to delete the whole VisualParadigm folder in the AppData/Roaming folder to run a fresh instance of VP but this action did not solve the problem too
Would you please tell me how to solve this issue ?
I’m using Visual Paradigm 16.1 Standard Edition on a Windows10 PC
Best Regards
