Hi
I have download evaluation copy of VP Suit 1.1 for windows but
I have problem with instaling SDE for the following products:
1-BEA : i have bea 8.1 installed , where is the hode directory ? is it the workshp root ? if so why it does not install it ?
2-Eclipse 3.0.1 , i specify the home as e:\dev\eclipse
but ask me to specify the correct home for eclipse .
I did not have any problems installing VP Suite into Eclipse. Is this Eclipse a fresh install? If so, run it once first, before installing the VP Suite. I was also wondering did you manually type this path in or did you use the File Chooser to select the path?
