The installation wizard only gives me the following options:
Visual Paradigm for UML 4.1
Smart Development Environment 2.1
SDE for Exlips/IBM…
SDE for Jbuilder
SDE for Netbeans
SDE for IntelliJ
SDE for JDeveloper
SDE for WebLogic
Now, where is Visual Studio? After installation I can use the Visual Paradigm tool, but not as a VS-plugin. It seems like I have downloaded a wrong version. But at the download screen it said “for visual studio”.
Sorry for my late response. During installation, the installer will check for the system registry to determine weather the VS .NET 2003 was being installed or not. Could you please check the following registry value exist in your system or not?
Indeed, I hadn’t such a key in “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths”.
I’ve just added the key “sdevenv.exe” with inside the strings:
“default” (path + exe) en “path”.
Should I reinstall Visual Paradigm?
Sorry for my late response. The SDE-VS option should be enabled in the installer after adding the registry key & values. Please make sure the key and values are:
Actually the registry value should be comes with the VS. We don’t know why it will be missed for some users (Maybe different build of the VS). Our engineers will keep on investigate on this problem.
