I’m using beta version of mac os mojave and was trying to open visual paradigm which in this case is not working. I would like to know if there is any beta nightly version that I can download or maybe a workaround in order to make it work?
Thanks,
Thanks,
Seems like I’m able to resolve the issue by my self.
for others with same issue the problem was the application was considered as unknown source and you have to approve unknown source application to be installed.
You can simply open terminal and run the following command “sudo spctl --master-disable” it will change the policy allowing you to run the application.
Thanks,
Thanks! it works
