After installing I get the following message. SDE cannot be started because the folder ECLIPSE_DIR/sde is not readable. Please set its read permissions and restart SDE.
I have looked and some of the files are set to read only but should be readable. I 've tried to change the settings to read write but for some reason its not changing the attribute.
it seems that it looks for the sde folder in /usr/share/eclipse although I installed it (like the others plug-ins) in my “private” environment /home/guillaume/.eclipse/org.eclipse.sdk.ide/updates/eclipse
Is it any config file that I can setup to make it pointing at the right place?
Cheers,
Guillaume
Sorry to keep you waiting. Could you send us your ${vp-suite-install-dir}/resources/.product_installation/xml file?
You said that the first log is at " /home/guillaume/vp.log", which looks abnormal. It should be inside ${eclipse} folder. Yet, the log appear under VP Suite installation folder is normal.
Could you send me your Eclipse configuration details? You can find it from the About dialog box of the Eclipse, and I am referring to the Eclipse at /home/guillaume/.eclipse/org.eclipse.sdk.ide/updates/eclipse/eclipse
