By the way, in the short cut properties ( advanced button) I found a checkbox to always run the shortcut as an administrator.
That way you don’t need to right click every time, but just double click the shortcut icon.
Maybe this is of interest for anyone that encounters the same problem
You are welcome. If there is any inquiry, please feel free to contact me again.
Lilian Wong[/quote]
But for me, it still don’t work. If I start it with admin right, it works, but not with normal user rights. Is there any chance to start vm-uml as normal user without that error msg?
What is the consequence of that error msg any way?
Thanks for your post. I’ve forwarded the problem to our engineers to follow-up. If there is any news about this issue, I’ll come back to you at once.
If you have execute and write permission to VP Suite installation directory, after you click OK on the error message, you should be able to work with the tool (the error shows due to enabled User Access Control in Windows Vista).
Lilian Wong[/quote]
Hi Lilian Wong
Are there any news? Even with UML 6.4 I get the error Msg if I log in as a user.
For me it is no solution to work with vista always as a admin.
Sorry for coming back to this post before. This problem is fixed in our current version (VP-UML 7.1) - the error message will not show when start VP-UML on Vista. You can download evaluation version of VP-UML 7.1 from our website ( http://www.visual-paradigm.com/download/vpuml.jsp ) for trying.
If there is anything I can do to help, please feel free to ask.
Lilian Wong[/quote]
Hi Lilian
What about 6.4 Sp2? We just recently bought new Licences and don’t want to update just because of this bug.
Seems VP-UML 6.4 SP2 does not cover this fix… You need to set the VP-UML launcher as Administrator to solve this problem.
By the way, there are numbers of new features and enhancements since VP-UML 6.4 SP2. Therefore it’s worth to upgrade to current version (VP-UML 7.1 SP1). You can find details about new features from: http://www.visual-paradigm.com/support/vpuml/releasenotes/711.jsp
This issue seems to be back in 8.0. I have altered my main Administrator user and am no loner able to use it for starting the app and so I cannot test the old work around.
good night, i have downloaded the vp-uml community edition, and follow the instructions, but when i click to run it, it says “the JVM could not be started, etc…” please, if anyone knows how to get this to work i appreciate it, im running windows 7 64bits, on a HP with 4gb of ram… Necrom15@gmail.com
