here are the configuration details:
*** Date: Mon May 14 10:07:31 CEST 2007
*** Platform Details:
*** System properties:
com.vp.vpsde.ec.VPSDEECMain=true
eclipse.buildId=M20070212-1330
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
/home/st_lamine/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
6210008
-clean
-vm
/usr/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1179129861603
eclipse.vm=/usr/bin/java
eclipse.vmargs=-Xms64m
-Xmx512m
-XX:MaxPermSize=256m
-Dcom.vp.vpsde.ec.VPSDEECMain=true
-jar
/home/st_lamine/eclipse/startup.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/home/st_lamine/eclipse/startup.jar
java.class.version=48.0
java.endorsed.dirs=/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/endorsed
java.ext.dirs=/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/ext
java.home=/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/i386/client:/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/i386:/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/…/lib/i386:/home/st_lamine/VP_Suite3.0/jre/lib/i386/server:/home/st_lamine/VP_Suite3.0/jre/lib/i386:/home/st_lamine/VP_Suite3.0/jre/…/lib/i386
java.runtime.name=Java™ 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_11-b06
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.FileSystemPreferencesFactory
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_11
java.vm.info=mixed mode
java.vm.name=Java HotSpot™ Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_11-b06
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.16.13-4-smp
org.osgi.framework.processor=i386
org.osgi.framework.system.packages=javax.accessibility,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.transaction,javax.transaction.xa,javax.xml.parsers,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stream,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/home/st_lamine/eclipse/configuration/org.eclipse.osgi/bundles
osgi.clean=true
osgi.configuration.area=file:/home/st_lamine/eclipse/configuration/
osgi.framework=file:/home/st_lamine/eclipse/plugins/org.eclipse.osgi_3.2.2.R32x_v20070118.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/home/st_lamine/eclipse/
osgi.instance.area=file:/home/st_lamine/workspace/
osgi.instance.area.default=file:/home/st_lamine/workspace/
osgi.logfile=/home/st_lamine/workspace/.metadata/.log
osgi.manifest.cache=/home/st_lamine/eclipse/configuration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/home/st_lamine/eclipse/plugins/org.eclipse.platform_3.2.2.r322_v20070117b/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/home/st_lamine/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/rt.jar:/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/i18n.jar:/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/jsse.jar:/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/jce.jar:/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/charsets.jar:/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-1_4_2-sun-1.4.2.11/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=unknown
user.country=US
user.dir=/home/st_lamine/eclipse
user.home=/home/st_lamine
user.language=en
user.name=st_lamine
user.timezone=Europe/Berlin
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.cdt (3.1.2.200702150621) "Eclipse C/C++ Development Tools"
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java Development Tools SDK"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform"
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP"
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.2.2.r322_v20070104-dCGKm0Ln38lm-8s) “Eclipse Project SDK”
*** Plug-in Registry:
com.ibm.icu (3.4.5.20061213) “International Components for Unicode for Java (ICU4J)” [Active]
com.ibm.icu.source (3.4.5.20061213) “International Components for Unicode for Java (ICU4J) source plug-in” [Resolved]
com.jcraft.jsch (0.1.28) “JSch” [Resolved]
com.vp.vpsde.ec (1.0.1) “Smart Development Environment for Eclipse” [Active]
org.apache.ant (1.6.5) “Apache Ant” [Resolved]
org.apache.lucene (1.4.103.v20060601) “Apache Lucene” [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) “Ant Build Tool Core” [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) “Ant UI” [Resolved]
org.eclipse.cdt (3.1.2.200702150621) “Eclipse C/C++ Development Tools” [Resolved]
org.eclipse.cdt.core (3.1.2.200702150621) “C/C++ Development Tools Core” [Active]
org.eclipse.cdt.core.linux (3.1.2.200702150621) “C/C++ Development Tools Core for Linux” [Resolved]
org.eclipse.cdt.core.linux.x86 (3.1.2.200702150621) “X86 Fragment” [Resolved]
org.eclipse.cdt.debug.core (3.1.2.200702150621) “C/C++ Development Tools Debug Model” [Resolved]
org.eclipse.cdt.debug.mi.core (3.1.2.200702150621) “C/C++ Development Tools GDB/MI CDI Debugger Core” [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.2.200702150621) “C/C++ Development Tools GDB/MI CDI Debugger UI” [Resolved]
org.eclipse.cdt.debug.ui (3.1.2.200702150621) “C/C++ Development Tools Debugger UI” [Resolved]
org.eclipse.cdt.doc.user (3.1.2.200702150621) “C/C++ Development User Guide” [Resolved]
org.eclipse.cdt.launch (3.1.2.200702150621) “C/C++ Development Tools Launching Support” [Resolved]
org.eclipse.cdt.make.core (3.1.2.200702150621) “C/C++ Standard make Build Core” [Active]
org.eclipse.cdt.make.ui (3.1.2.200702150621) “C/C++ Standard make Build UI” [Active]
org.eclipse.cdt.managedbuilder.core (3.1.2.200702150621) “C/C++ Managed Builder Core” [Resolved]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.2.200702150621) “GNU Managed Build Definitions” [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.2.200702150621) “C/C++ Managed Builder UI” [Active]
org.eclipse.cdt.refactoring (3.1.2.200702150621) “C/C++ Refactoring” [Resolved]
org.eclipse.cdt.ui (3.1.2.200702150621) “C/C++ Development Tools UI” [Active]
org.eclipse.compare (3.2.1.M20060711) “Compare Support” [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) “Core Boot” [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) “Commands” [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) “Eclipse Content Mechanism” [Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) “Expression Language” [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) “File Buffers” [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) “Core File Systems” [Resolved]
org.eclipse.core.filesystem.linux.x86 (1.0.0.v20060603) “Core File System for Linux” [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) “Eclipse Jobs Mechanism” [Active]
org.eclipse.core.resources (3.2.2.R32x_v20061218) “Core Resource Management” [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) “Core Resource Management Compatibility Fragment” [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) “Core Runtime” [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) “Core Runtime Plug-in Compatibility” [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) “Authorization Compatibility Plug-in” [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907) “Eclipse Registry Compatibility Fragment” [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) “Core Variables” [Resolved]
org.eclipse.debug.core (3.2.1.v20060823) “Debug Core” [Active]
org.eclipse.debug.ui (3.2.2.r322_v20070202) “Debug UI” [Active]
org.eclipse.equinox.common (3.2.0.v20060603) “Common Eclipse Runtime” [Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) “Eclipse Preferences Mechanism” [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) “Extension Registry Support” [Active]
org.eclipse.help (3.2.2.R322_v20061213) “Help System Core” [Active]
org.eclipse.help.appserver (3.1.100.v20060602) “Help Application Server” [Resolved]
org.eclipse.help.base (3.2.2.R322_v20061207) “Help System Base” [Active]
org.eclipse.help.ui (3.2.0.v20060602) “Help System UI” [Active]
org.eclipse.help.webapp (3.2.2.R322_v20061114) “Help System Webapp” [Resolved]
org.eclipse.jdt (3.2.1.r321_v20060823) “Eclipse Java Development Tools” [Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) “Java Annotation Processing Core” [Installed]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) “Java Annotation Processing UI” [Installed]
org.eclipse.jdt.core (3.2.3.v_686_R32x) “Java Development Tools Core” [Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) “Java Code Manipulation Functionality” [Resolved]
org.eclipse.jdt.debug (3.2.2.r322_v20070130) “JDI Debug Model” [Active]
org.eclipse.jdt.debug.ui (3.2.2.r322_v20061205) “JDI Debug UI” [Active]
org.eclipse.jdt.doc.isv (3.2.1.r322_v20070109) “Eclipse JDT Plug-in Developer Guide” [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) “Eclipse Java Development User Guide” [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) “Java Development Tools JUnit support” [Active]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) “Java Development Tools JUnit runtime support” [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) “Java Development Tools JUnit4 runtime support” [Installed]
org.eclipse.jdt.launching (3.2.2.r322_v20061114) “Java Development Tools Launching Support” [Active]
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) “Eclipse Java Development Tools SDK” [Resolved]
org.eclipse.jdt.ui (3.2.2.r322_v20070124) “Java Development Tools UI” [Active]
org.eclipse.jface (3.2.2.M20061214-1200) “JFace” [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) “JFace Data Binding” [Resolved]
org.eclipse.jface.text (3.2.2.r322_v20070104) “JFace Text” [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) “Refactoring Core” [Resolved]
org.eclipse.ltk.ui.refactoring (3.2.2.r322_v20070124) “Refactoring UI” [Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) “OSGi Release 3 Services” [Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) “OSGi R3 Utility Classes” [Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) “Eclipse Plug-in Development Environment” [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) “Plug-in Development Environment Build Support” [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) “Plug-in Development Core” [Resolved]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) “Eclipse Plug-in Development User Guide” [Resolved]
org.eclipse.pde.junit.runtime (3.2.0.v20060605) “PDE JUnit Plug-in Test” [Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) “Plug-in Development Environment Runtime” [Resolved]
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) “Eclipse Plug-in Development Environment Developer Resources” [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) “Plug-in Development UI” [Resolved]
org.eclipse.platform (3.2.2.r322_v20070117b) “Eclipse Platform” [Active]
org.eclipse.platform.doc.isv (3.2.2.R32x_v20070115) “Eclipse Platform Plug-in Developer Guide” [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) “Eclipse Workbench User Guide” [Resolved]
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK) “Eclipse Platform Plug-in Developer Resources” [Resolved]
org.eclipse.platform.source.linux.gtk.x86 (3.2.2.r322_v20070119-RQghndJN8IM0MsK) “Eclipse Platform Plug-in Developer Resources” [Resolved]
org.eclipse.rcp (3.2.0.v20060605) “Eclipse RCP” [Resolved]
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) “Eclipse RCP Plug-in Developer Resources” [Resolved]
org.eclipse.rcp.source.linux.gtk.x86 (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) “Eclipse RCP Plug-in Developer Resources” [Resolved]
org.eclipse.sdk (3.2.2.r322_v20070212) “Eclipse Project SDK” [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) “Search Support” [Active]
org.eclipse.swt (3.2.2.v3236b) “Standard Widget Toolkit” [Resolved]
org.eclipse.swt.gtk.linux.x86 (3.2.2.v3236) “Standard Widget Toolkit for GTK 2.0” [Resolved]
org.eclipse.team.core (3.2.2.M20061114) “Team Support Core” [Active]
org.eclipse.team.cvs.core (3.2.2.M20061205) “CVS Team Provider Core” [Resolved]
org.eclipse.team.cvs.ssh (3.2.1.M20061205) “CVS SSH Core” [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.1.M20061205) “CVS SSH2” [Resolved]
org.eclipse.team.cvs.ui (3.2.2.M20061121) “CVS Team Provider UI” [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) “Team Support UI” [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) “Text” [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) “Tomcat Wrapper” [Resolved]
org.eclipse.ui (3.2.1.M20061108) “Eclipse UI” [Active]
org.eclipse.ui.browser (3.2.0.v20060602) “Browser Support” [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) “Cheat Sheets” [Active]
org.eclipse.ui.console (3.1.100.v20060605) “Console” [Resolved]
org.eclipse.ui.editors (3.2.1.r321_v20060721) “Default Text Editor” [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) “External Tools” [Active]
org.eclipse.ui.forms (3.2.0.v20060602) “Eclipse Forms” [Active]
org.eclipse.ui.ide (3.2.1.M20060915-1030) “Eclipse IDE UI” [Active]
org.eclipse.ui.intro (3.2.2.R322_v20061214) “Welcome Framework” [Active]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) “Universal Welcome” [Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) “Common Navigator View” [Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) “Navigator Workbench Components” [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) “R21 Presentation Plug-in” [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) “Views” [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) “Tabbed Properties View” [Resolved]
org.eclipse.ui.workbench (3.2.2.M20070119-0800) “Workbench” [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) “Workbench Compatibility” [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) “Text Editor Framework” [Active]
org.eclipse.update.configurator (3.2.2.R32x_v20070111) “Install/Update Configurator” [Active]
org.eclipse.update.core (3.2.3.R32x_v20070118) “Install/Update Core” [Active]
org.eclipse.update.core.linux (3.2.0.v20060605) “Install/Update Core for Linux” [Resolved]
org.eclipse.update.scheduler (3.2.2.R32x_v20061214) “Automatic Updates Scheduler” [Active]
org.eclipse.update.ui (3.2.2.R32x_v20070111) “Install/Update UI” [Active]
org.junit (3.8.1) “JUnit Testing Framework” [Resolved]
org.junit4 (4.1.0.1) “JUnit Testing Framework Version 4” [Installed]
system.bundle (3.2.2.R32x_v20070118) “OSGi System Bundle” [Active]
*** User Preferences:
#Mon May 14 10:07:31 CEST 2007
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.cdt.debug.ui/org.eclipse.debug.ui.DebugView.org.eclipse.cdt.debug.ui.cDebug.show_full_paths=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpathVariable.JRE_LIB=/home/st_lamine/jre1.6.0_01/lib/rt.jar
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0" encoding\="UTF-8"?>\n<web-browsers current=“0”>\n\n<external location="/opt/kde3/bin/konqueror" name=“Konqueror”/>\n
@org.eclipse.cdt.debug.core=3.1.2.200702150621
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.width=
/instance/org.eclipse.ui.ide/platformState=1179129862267
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpathVariable.JRE_SRCROOT=
/project/Simulation\ Tool/org.eclipse.cdt.managedbuilder.core/environment/buildEnvironmentLibrary/cdt.managedbuild.config.gnu.exe.debug.1835353710=<?xml version\="1.0" encoding\="UTF-8"?>\n\n<variable name=“LIBRARY_PATH” operation=“remove”/>\n\n
file_export_version=3.0
@org.eclipse.pde.core=3.2.1.v20060915-0800
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
@org.eclipse.jdt.ui=3.2.2.r322_v20070124
/instance/org.eclipse.ui.editors/lineNumberRuler=true
/instance/org.eclipse.pde.core/platform_path=/home/st_lamine/eclipse
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.cdt.debug.ui/org.eclipse.debug.ui.BreakpointView.org.eclipse.cdt.debug.ui.cDebug.show_full_paths=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpathVariable.JRE_SRC=
@org.eclipse.ui.browser=3.2.0.v20060602
@org.eclipse.jdt.launching=3.2.2.r322_v20061114
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.VariableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
@org.eclipse.debug.ui=3.2.2.r322_v20070202
/instance/org.eclipse.core.resources/description.autobuilding=false
/instance/org.eclipse.ui/showIntro=false
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/project/Simulation\ Tool/org.eclipse.cdt.core/indexerId=org.eclipse.cdt.core.domsourceindexer
/instance/org.eclipse.cdt.core/indexer=org.eclipse.cdt.core.domsourceindexer
@org.eclipse.jdt.core=3.2.3.v_686_R32x
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=/home/st_lamine/workspace
/instance/org.eclipse.pde.core/saved_platform0=/home/st_lamine/eclipse
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.views_to_not_open=org.eclipse.debug.ui.DebugView,
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
@org.eclipse.ui.ide=3.2.1.M20060915-1030
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.common_source_containers=<?xml version\="1.0" encoding\="UTF-8"?>\n\n<sourceContainers duplicates=“false”/>\n\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder.resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.cdt.ui=3.1.2.200702150621
@org.eclipse.core.resources=3.2.2.R32x_v20061218
@org.eclipse.ui=3.2.1.M20061108
@org.eclipse.jdt.debug.ui=3.2.2.r322_v20061205
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launching.PREF_VM_XML=<?xml version\="1.0" encoding\="UTF-8"?>\n<vmSettings defaultVM=“57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType13,1178817389317” defaultVMConnector="">\n<vmType id=“org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType”>\n<vm id=“0” name=“jdk1.5.0_07” path="/usr/local/jdk1.5.0_07" javadocURL=“http://java.sun.com/j2se/1.5.0/docs/api/”/>\n<vm id=“1178806114154” name=“jre1.5.0_11” path="/home/st_lamine/jre1.5.0_11" javadocURL=“http://java.sun.com/j2se/1.5.0/docs/api/”/>\n<vm id=“1178817389311” name=“VP_Suite3.0” path="/home/st_lamine/VP_Suite3.0" javadocURL=“http://java.sun.com/j2se/1.5.0/docs/api/”/>\n<vm id=“1178817389317” name=“jre1.6.0_01” path="/home/st_lamine/jre1.6.0_01"/>\n<vm id=“1178817389330” name=“VP_Suite3.0(1)” path="/home/st_lamine/VP_Suite/VP_Suite3.0" javadocURL=“http://java.sun.com/j2se/1.5.0/docs/api/”/>\n\n\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=2
@org.eclipse.ui.editors=3.2.1.r321_v20060721
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocations.migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles.version=10
/project/Simulation\ Tool/org.eclipse.cdt.managedbuilder.core/environment/buildEnvironmentInclude/cdt.managedbuild.config.gnu.exe.debug.1835353710=<?xml version\="1.0" encoding\="UTF-8"?>\n\n<variable name=“CPATH” operation=“remove”/>\n<variable name=“CPLUS_INCLUDE_PATH” operation=“remove”/>\n\n
@org.eclipse.search=3.2.1.r321_v20060726
/instance/org.eclipse.search/org.eclipse.search.defaultPerspective=org.eclipse.search.defaultPerspective.none
@org.eclipse.cdt.debug.ui=3.1.2.200702150621
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Monospace|10|0|GTK|1|;
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
@org.eclipse.cdt.core=3.1.2.200702150621
*** Current Install Configuration:
Install configuration:
Last changed on May 10, 2007
Location: file:/home/st_lamine/eclipse/configuration/org.eclipse.update/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.platform, Version: 3.2.2.r322_v20070119-RQghndJN8IM0MsK
ID: org.eclipse.rcp, Version: 3.2.2.r322_v20070104-8pcviKVqd8J7C1U
ID: org.eclipse.platform.source, Version: 3.2.2.r322_v20070119-RQghndJN8IM0MsK
ID: org.eclipse.jdt, Version: 3.2.2.r322_v20070104-R4CR0Znkvtfjv9-
ID: org.eclipse.jdt.source, Version: 3.2.2.r322_v20070104-R4CR0Znkvtfjv9-
ID: org.eclipse.pde, Version: 3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG
ID: org.eclipse.pde.source, Version: 3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG
ID: org.eclipse.sdk, Version: 3.2.2.r322_v20070104-dCGKm0Ln38lm-8s
ID: org.eclipse.rcp.source, Version: 3.2.2.r322_v20070104-8pcviKVqd8J7C1U
ID: org.eclipse.cdt, Version: 3.1.2.200702150621
Configured plug-ins:
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2.0.v20060605-1400.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.navigator.resources_3.2.1.M20060906-0800b.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.debug.core_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.debug_3.2.2.r322_v20070130/
file:/home/st_lamine/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.2.2.r322_v20070124.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jface.text_3.2.2.r322_v20070104.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.doc.isv_3.2.1.r322_v20070109.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.team.core_3.2.2.M20061114.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.update.core_3.2.3.R32x_v20070118.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.update.core.linux_3.2.0.v20060605.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.0.I20060605-1400.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.compare_3.2.1.M20060711.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v20060602.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.tomcat_4.1.130.v20060601/
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400/
file:/home/st_lamine/eclipse/plugins/org.eclipse.team.ui_3.2.1.M200608151725.jar
file:/home/st_lamine/eclipse/plugins/org.junit_3.8.1/
file:/home/st_lamine/eclipse/plugins/org.eclipse.rcp.source_3.2.2.r322_v20070104-8pcviKVqd8J7C1U/
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.apt.core_3.2.1.R32x_v20060822-2100.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.help.base_3.2.2.R322_v20061207.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.junit.runtime_3.2.1.r321_v20060721/
file:/home/st_lamine/eclipse/plugins/org.eclipse.jface_3.2.2.M20061214-1200.jar
file:/home/st_lamine/eclipse/plugins/com.vp.sde.eclipse/
file:/home/st_lamine/eclipse/plugins/org.eclipse.help.webapp_3.2.2.R322_v20061114/
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3.2.1.M20060830-0800.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.search_3.2.1.r321_v20060726.jar
file:/home/st_lamine/eclipse/plugins/org.apache.lucene_1.4.103.v20060601/
file:/home/st_lamine/eclipse/plugins/org.eclipse.platform.doc.isv_3.2.2.R32x_v20070115.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.jobs_3.2.0.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui_3.2.1.M20061108.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.resources.compatibility_3.2.0.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.debug.ui_3.2.2.r322_v20061205.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.source_3.2.2.r322_v20070104-R4CR0Znkvtfjv9-/
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.workbench_3.2.2.M20070119-0800.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.make.ui_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.core_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.launch_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.update.ui_3.2.2.R32x_v20070111.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.ui_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.junit4_4.1.0.1/
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.launching_3.2.2.r322_v20061114.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.doc.user_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.osgi.services_3.1.100.v20060601.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.2.1.r321_v20060823.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ant.ui_3.2.1.r321_v20060828.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.platform.source_3.2.2.r322_v20070119-RQghndJN8IM0MsK/
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.junit_3.2.1.r321_v20060810/
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.intro.universal_3.2.1.R321_v20060905/
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.managedbuilder.gnu.ui_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.managedbuilder.core_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.2.M20061121.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.1.M20061205.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.rcp.source.linux.gtk.x86_3.2.2.r322_v20070104-8pcviKVqd8J7C1U/
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.externaltools_3.1.101.r321_v20060802.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.core.linux_3.1.2.200702150621/
file:/home/st_lamine/eclipse/plugins/org.eclipse.equinox.preferences_3.2.1.R32x_v20060717.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.swt_3.2.2.v3236b.jar
file:/home/st_lamine/eclipse/plugins/com.ibm.icu_3.4.5.20061213.jar
file:/home/st_lamine/eclipse/plugins/com.jcraft.jsch_0.1.28.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.debug.mi.ui_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.sdk_3.2.2.r322_v20070212/
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.filebuffers_3.2.1.r321_v20060721.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.help.ui_3.2.0.v20060602.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.2.1.R32x_v20060907/
file:/home/st_lamine/eclipse/plugins/org.eclipse.osgi.util_3.1.100.v20060601.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.pde.build_3.2.1.r321_v20060823/
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.make.core_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.pde.runtime_3.2.0.v20060605.jar
file:/home/st_lamine/eclipse/plugins/org.apache.ant_1.6.5/
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.refactoring_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.update.scheduler_3.2.2.R32x_v20061214.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.ide_3.2.1.M20060915-1030.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jface.databinding_1.0.0.I20060605-1400.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.junit4.runtime_1.0.1.r321_v20060905.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.ui_3.2.2.r322_v20070124.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.equinox.registry_3.2.1.R32x_v20060814.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.core.linux.x86_3.1.2.200702150621/
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.managedbuilder.ui_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.debug.ui_3.2.2.r322_v20070202.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.core.manipulation_1.0.1.r321_v20060721.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.help_3.2.2.R322_v20061213.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt_3.2.1.r321_v20060823.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.pde.core_3.2.1.v20060915-0800.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.debug.mi.core_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.help.appserver_3.1.100.v20060602.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.1.R321_v20060720.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.core_3.2.3.v_686_R32x.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.console_3.1.100.v20060605.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.views_3.2.1.M20060906-0800.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.commands_3.2.0.I20060605-1400.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.team.cvs.core_3.2.2.M20061205.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.cdt.debug.ui_3.1.2.200702150621.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.resources_3.2.2.R32x_v20061218.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.pde.junit.runtime_3.2.0.v20060605.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.pde_3.2.1.v20060810-0800.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.rcp_3.2.0.v20060605.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.pde.ui_3.2.1.v20060816-0800.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.filesystem.linux.x86_1.0.0.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.update.configurator_3.2.2.R32x_v20070111.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.pde.source_3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG/
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.apt.ui_3.2.1.R32x_v20060822-2100.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.expressions_3.2.2.r322_v20070109a.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.platform.source.linux.gtk.x86_3.2.2.r322_v20070119-RQghndJN8IM0MsK/
file:/home/st_lamine/eclipse/plugins/org.eclipse.debug.core_3.2.1.v20060823.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.core.variables_3.1.100.v20060605.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.platform.doc.user_3.2.1.R32x_v200608101155.jar
file:/home/st_lamine/eclipse/plugins/com.ibm.icu.source_3.4.5.20061213/
file:/home/st_lamine/eclipse/plugins/org.eclipse.jdt.doc.user_3.2.0.v20060605-1400.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.editors_3.2.1.r321_v20060721.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.pde.doc.user_3.2.1.v20060816-0800.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.text_3.2.0.v20060605-1400.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.intro_3.2.2.R322_v20061214.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.swt.gtk.linux.x86_3.2.2.v3236.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ui.navigator_3.2.1.M20060913-0800.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.1.M20061205.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531.jar
file:/home/st_lamine/eclipse/plugins/org.eclipse.platform_3.2.2.r322_v20070117b/
