I export my model using the Project Publisher. Is there an option to disable the “Jump to” select box created in every diagram?
/planetenxin
/planetenxin
Hi Planetenxin,
Thanks for your inquiry. In order to remove “Jump to” combo box from published pages, please follow the steps below:
By the way, if you want to show Jump to combo box again, you can either remove the file or change the “true” value to “false” in the properties file. Both approach needs to restart VP-UML in order to take effect.
Hope this helps. Please feel free to ask if there is anything else I can help.
publisher.properties
