Is it possible to use the Visual Paradigm tool to import a Rational Rose .mdl file and then export it to an .xmi file ? For what I’ve read, is it possible to import Rational Rose projects, but as far as I’ve tried, I get a message of ‘corrupted file’ when trying to import a .mdl file.
What really interests me is to pass the information contained in a mdl file to an xmi one. Does anyone know how to do it, with or without Visual Paradigm?
hi all,
i am using rational rose to create state chart diagram can anybody tell me how to save it in xml or xmi format…or to convert .mdl file to xmi or xml format,
thanks
Is it possible to do a reverse engineering and translate a C++ file into UML file? I would like that in the resulting UML file there will be data about every method, if this is virtual or not.
How can I translate the resulting UML file into a XML file ? I know that xmi has a lot of limitation about the given UML file: it can’t parse a file with templates and with multiple inheritance. What software is recommended for this?
Could any one of you tell me as how to convert export the state chart diagrams drawn in Rational Rose Real Time to an XMI or XML format. I’m using Rational Rose Real Time version 7.0
Thanks for your post and we are sorry about our late late reply. You can reverse C++ source by Instant Reverse in VP-UML/SDE Standard Edition or above, the reversed elements will be virtual automatically. You can get more details about Instant Revers for C++ from the following link: http://www.visual-paradigm.com/product/vpuml/demos/reversecode/instantreverse.jsp
hi frnds,
pls tel me how to write a parser for .mdl file of rational rose for separating the mutator,
accessor and other classified class attributes a
nd methods pls frnds do help me out.
