how customize the tableblock ?
can i specify the height of a row ?
can i specify the align in a cell (left, center, right) ?
<TableBlock colWidths = "1000,1100,5000,2950" tableWidth = "15500" alignment = "right">
<TableRow>
<TableCell leftBorderEnable = "false" rightBorderEnable = "false" color = "230, 230, 230">
<StaticText content = "Version" style = "Column header 1"/>
</TableCell>
<StaticText content = "Date" style = "Column header 1"/>
</TableCell>
<StaticText content = "Comments" style = "Column header 1"/>
</TableCell>
<StaticText content = "Authors" style = "Column header 1"/>
</TableCell>
</TableRow>
<TableRow>
<TableCell leftBorderEnable = "false" rightBorderEnable = "false">
<StaticText content = "" style = "Table Contents"/>
</TableCell>
</TableCell>
</TableCell>
</TableCell>
</TableRow>
</TableBlock>
Hi user,
Thanks for your post. I’ll check with our engineers and come back to you once I got any feedback. At the mean time, if you have any inquiry, please do not hesitate to have a post.
Hi user,
For alignment, you can add alignment=“right” on <StaticText …>, but please note that if StaticText has set style=“xxx”, the style’s alignment will overwrite the alignment=“xxx”
Here are 2 ways to resolve this problem:
- do not set style=“xxx”, but the font will lose as well
- customize your own style in OpenOffice (Report Writer) with alignment settings, and then set the new style into <StaticText…>
More details of customizing new style for alignment, please refer to the following flash movie:
http://files2.visual-paradigm.com/FlashDemo/ReportWriter/customize_style_alignment.htm
For specifying row height, we enhanced to support it in our latest patch, which you can downloaded from:
http://files2.visual-paradigm.com/200901/Patch/sp1_20081230r/VP_Suite_Windows_3_4_sp1_20081230r.exe
When you add @height for <TableRow…>, you will get the customized height in your table. If you do not define height, the row height will auto fit to content.
If there is any further inquiry, please feel free to ask.
we have a style tag, a alignment tag
do we have a font tag ?
[quote=LilianWong]Hi user,
Lilian Wong[/quote]
Thanks a lot
an other question : how paint a line on two ?
ex :
first line : blue
second : red
third : blue
4th : red
etc …
(and the line 0 in an other : green; this line corresponds to the name of the columns)
Lilian Wong[/quote]
Hi user,
Thanks for replying. About how to paint the text with pair color, we enhanced to support rowBackgroundColor for <TableBlock …> and backgroundColor for <TableRow …>. Please download and install the latest patch in the following link to access the enhancement.
http://files2.visual-paradigm.com/200902/Patch/sp1_20081230v/VP_Suite_Windows_3_4_sp1_20081230v.exe
For how to configure the background color, please refer to the 2nd image.
And Font is included in Style (please see the 1st image below), you can customize the default style in the Style settings.
Alternatively, you can configure your own style and apply it to your document. Details can be found from the following flash movie:
http://files2.visual-paradigm.com/FlashDemo/ReportWriter_customize_doc_style.htm
Hope these help.
I try to do what is explained in your sample, but it doesn’t work on my report writer
It seems that the rowBackgroundColors doesn’t work
Could you please help me to solve the problem?
I post the code that I wrote.
Thanks in advance!
Hi user,
Thanks for replying. You are using incorrect color code “#COCOCO, #EOEOEO”.
It should be “#C0C0C0, #E0E0E0” (should be “zero” instead of “O”).
Hi Lilian!
Ups… It works now, I didn’t install the right patch
Thanks for your precious help
Hi user,
You are welcome. Have a nice day!
