I am looking into using the Requirements Capturing facilities within the SDE, but can not find any documentation anywhere. What I am looking for is firstly how to use the section within the SDE context, and secondly for any guidance, documentation on usage of the elements with in the section in line with UML.
Hopefully someone will be able to point me in the right direction.
Thank you for your interest in our products. Requirement capturing can be done with the following features in SDE (the links below are flash movies related to the features).
Business Process Diagram
The Business Process Diagram helps you to understand complex business workflow using the OMG’s BPMN. You can have better understand the entire business activities (problem space) and identify use cases (solution space) from which the parts of activities planned to be automated. http://www.visual-paradigm.com/product/sde/ec/demos/bpmodeling/bpd.jsp
Requirement Diagram
SysML includes a graphical construct called requirement diagram to represent text based requirements and relate them to other model elements. The requirements diagram captures requirements hierarchies and requirements derivation, and the satisfy and verify relationships allow a modeler to relate a requirement to a model element that satisfies or verifies the requirements. The requirement diagram provides a bridge between the typical requirements management tools and the system models http://www.visual-paradigm.com/product/sde/ec/demos/requirements/requirement.jsp http://www.visual-paradigm.com/product/sde/ec/demos/requirements/definecusttype.jsp
