Is there any way to reset ORMID for any record in SQL database set by DB-VA after deleting some records. For example I created records
Record1
Record2
Record3
Record4
And their ORMIDs are 1, 2, 3, 4. Then when I delete Record4 form the database, next record will be created with
ORMID=5 regardless to erased previos record with ORMID=4, is there any method for ORMID recalculation after some records deleting.
I am afraid the built-in ID generator cannot fulfill your need. I suggest you achieve your need by using ID generator. Attached is a document that talks about it.
Hope this helps. Feel free to let me know if there are any questions.
