I have a problem when I copy a hi resolution screenshot or picture into the description field of a process. The quality of the image seriously deteriorates when I copy it into the description field. It makes the documentation look shabby when i use the doc composer to generate the documentation.
Thank you for your post. Unfortunately, we are unable to repeat your case. In our testing, the quality of hi-quality image is fine when pasting in the description field. It does look a bit shabby when being shown in Doc. Composer, but the exported reports (e.g. PDF) looks fine. Could you send us a sample project for checking? One that contains the problem shape and Doc. Composer document would be great.
Thank you for studying the problem. I think you are right and it only seems like resolution loss in the description field. When I print the pdf, it seems to be ok.
We stumbled into the problem while copying text and pictures from Word documents into the description field. I suspect that Word already performed some kind of compression on the original high resolution pictures, which lead to shabby pictures in the description field.
