Let’s say I have a very simple template with a default parameter:
template< typename KEY = unsigned int>
class TEventManager
When a class inherits or uses this template then the Reverse C++ fails. The example, the following fails:
class CMyMgr : public TEventManager<>
class CMyClass
vitual void OnCallback( TEventManager<>::param_type dwParam );
If I simply replace TEventManager<> by TEventManager then everything works. Is there a way for fix this issue in VPP?
I’m using VPP v12 (Build 20151101).
