I have the following code that Reverse C++ Code cannot process - it generates an error.
#pragma warning( push )
#pragma warning( disable: 4231 )
WEAPONAGENT_DLL_EXTERN template class WEAPONAGENT_DLL TSingleton<class CSimSettings>;
#pragma warning( pop )
Although I predefined the WEAPONAGENT_DLL and WEAPONAGENT_DLL_EXTERN macros in the “Reverse Code” dialog, the line of code still fails.
If I simply comment out the lines above, then reverse code is successful. Is there any way that VPP can handle this use case.
I’m using VPP v12 (Build 20151101)
