I have reverse engineered a large schema into DB-Visual Architect. Most of the tables were built properly but several have no definition. How can I best fix this without disturbing all the other definitions?
Can I run another reverse engineer of the subset that didn’t work the first time? Other options?
Thanks for your post. Would you mind sending the schema and vp.log file (inside VPSuite/bin folder) to lilian@visual-paradigm.com for investigation? Thanks in advance!
thanks Lillian - I ended up trying to re-reverse engineer the selected tables and that worked without disturbing the other objects from the full reverse engineer.
