Hi
I’m evaluating Visaul-paradigm SDE for Visual Studio .NET 2003
This addin is way cool and very easy to use. You just have correct the small details! Or maybe i’ve overlooked something.
I Tried to reverse engineer this small example.
using System;
using TestUML;
namespace TestUML
public class Wheel
public Wheel()
// TODO: Add constructor logic here
public class Volvo
private Wheel[] whels = new Wheel[4];
public Volvo()
class TheApp
private Volvo myCar = new Volvo();
[STAThread]
static void Main(string[] args)
// TODO: Add code to start application here
and expected the class diagram to Show the associations between Volvo an wheel as an association line in the diagram. Not just as a field-string inside the class - box.
I Realized that this happened because I declare an array
Somehow VP-SDE doesn’t handle the [] correctly!
Am I right?
It should generate an association line with multiplicity 1 and 4.
If I change
to
private Wheel whels = new Wheel();
the association line is formed as exspected.
This must be fixed.
BR Christian Johansen
