Trying out the enterprise edition for 30 days. Integrated with Intellij (latest) Can’t figure out how to reverse engineer existing project / package / class(es) into UML diagrams. Does anyone know how to do this ?
I open Instant Reverse and then try to add source folder . A dialog comes up that says Select Directories. My problem starts here. I cannot select any of the directories presented (nothing happens when I click on any of them) and also I cannot use the dialog to navigate to the actual location of my source code.
Any ideas? Thank you !
Solution- the dialog which appears is not properly sized when it launches and you can’t see there’s another part to the dialog. Manually expand the dialog and you’ll see you can navigate using it.
