Hi guys
I’m using SDE for reverse engineering in java. I’m using the Community Edition
All Things work fine except one thing.
when i’m trying to export the diagram to an image file of any kind then on the background i’m getting “Evaluation copy” written in the background all over it.
So i can’t use this anywhere.
Is there any way to get rid of this background text or i need to find some other tool
can anyone help me with this.
Thanks a lot
Hi ambika,
The watermark that appear on the exported image is due to the limitation of an evaluation copy. It will no longer exist in purchased copy.
For the Community Edition, if you create more than one diagram per any type, the exported image will show pattern watermark. If you create at most one diagram per type, the exported image will show a single-lined watermark.
