I am using Visual Paradigm 10.1 Standard Edition Build 20130509 and some Java classes cannot be reverse engineered.
Is it not yet supported in Visual Paradigm?
I am on Linux, the no install version. Is the problem maybe that the integrated jre is only Java 1.6?
Thanks for your help in advance
I now registered here
attached the error log.
Does someone know what’s wrong?
EDIT: I changed the jre version to 1.7, error stays.
What’s wrong here?
vpuml.log
I attached my error log:
vpuml.log
Probably because you use the diamond operator :
final Map<String, String> map = new HashMap<>();
I don’t know how to workaround this problem.
you should put like this for this error
final Map<String, String> map = new HashMap<String, String>();
it will be work.
