I have installed SDE Community Edition but I’m not able to Import a Rose file (mdl). The Import and Export functiona are disabled. I started a new Project (Windows application) to store the imported Rose model but somehow the functions are greyed out. What have I done wrong??
Thanks for any help!!
Hi vherbst,
Which IDE are you using the SDE with? Which build are you using?
I tried Version 4.0 20041218f and the Import and Export functions are not greyed out.
Martyn
I have Version 2.0- which I downloaded last Friday from your website.
Here the Logfile. May be some Java classes are missing?
[ Mon Jan 24 16:53:47 CET 2005]: Start Smart Development Environment Community Edition for Visual Studio [SDE CE-VS]: 2.0 (20041118a)
null
No toolbar found for: Teamwork
Something wrong in synCodeFromUMLProject method!
at v.bqz.run(:145)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:178)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:454)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:145)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:137)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:100)
at v.bqz.run(:145)
Something wrong in creating DiagramUIEditor: false
java.lang.NullPointerException: component argument pData
at sun.awt.windows.Win32Renderer.doFillRect(Native Method)
at sun.awt.windows.Win32Renderer.fillRect(Win32Renderer.java:135)
at sun.java2d.SunGraphics2D.fillRect(SunGraphics2D.java:2066)
at sun.java2d.SunGraphics2D.clearRect(SunGraphics2D.java:2111)
at sun.awt.RepaintArea.paint(RepaintArea.java:172)
at sun.awt.windows.WComponentPeer.handleEvent(WComponentPeer.java:260)
at java.awt.Component.dispatchEventImpl(Component.java:3678)
at java.awt.Container.dispatchEventImpl(Container.java:1627)
at java.awt.Component.dispatchEvent(Component.java:3477)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:456)
Exception during disposal:
java.lang.reflect.InvocationTargetException
at java.awt.EventQueue.invokeAndWait(EventQueue.java:834)
at java.awt.Window.dispose(Window.java:574)
at v.nna.w(:50)
at v.udu.run(:104)
Caused by: java.lang.NullPointerException: null pData
at sun.awt.windows.WFramePeer.getState(Native Method)
at java.awt.Frame.getExtendedState(Frame.java:755)
at java.awt.Frame.getState(Frame.java:730)
at java.awt.Frame.removeNotify(Frame.java:877)
at java.awt.Window$1DisposeAction.run(Window.java:557)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:171)
saveGenericShapeInstance(…)v.mwj@9d52ac
[Tue Jan 25 08:47:55 CET 2005]: Start Smart Development Environment Community Edition for Visual Studio [SDE CE-VS]: 2.0 (20041118a)
No JNI Library 8
[ Tue Jan 25 08:48:09 CET 2005]: Start Smart Development Environment Community Edition for Visual Studio [SDE CE-VS]: 2.0 (20041118a)
null
Hi vherbst,
Sorry, about the version error, I was testing on VP-UML 4.0. It seems that your VP-SDE for Visual Studio is a bit outdated. Can you please update to the latest one and see if this works?
Hope this helps.
Martyn
Actually there is only Version SDE for Visual Studio® .NET 2.0 available. This is the current version on the Paradigm website. Could there b e a newer one elesewhere?
Dear vherbst,
Thank you for your message. Please note that the Rose Import feature only available to the Standard Edition or above. If you have any further questions, please feel free to contact us again.
Rain
