I am using VP-UML 5.0 V20051020 under linux with Java™ 2 Runtime Environment, Standard Edition (build 1.5.0_03-b07) and I have the following problem:
the mouse scrolling inside of the diagram window is very slow. In the other window parts it’s ok. Where can I change this behaviour?
I have looked in the settings and in the manuals but I found nothing
Please help. Thanks.
Best Regards,
Thomas
January 4, 2006, 8:20am
2
Hi Thomas,
Sorry for the problem. I will forward your suggestion to our engineers and see if you can fine-tine the scrolling behavior (or make it customizable).
At this moment, please use the Diagram Overview functionality to determine the part of diagram you wish to view.
Best Regards,
Hi Jick,
thanks for reply. The scrolling problem is in all diagrams! with other window parts I mean all other windows like modeller view or logical view.
Best Regards,
Thomas
January 5, 2006, 10:43am
4
Hi Thomas,
Thanks for the reply. I understand the problem you talked about. What I mean is you can, as a workaround, select from Diagram Overview the portion of diagram to be displayed on the diagram pane. (please refer to the attachment)
Best Regards,
January 13, 2006, 2:29pm
5
Hi Thomas,
I would like to notify you that our engineers are now fixing the slow scrolling issue. Meanwhile, you can scroll with ‘shift’ button pressed. This will increase the distance per each scroll.
Best Regards,
February 6, 2006, 9:48am
6
Hi Thomas,
I would like to notify you that the slow scrolliong problem you raised before is fixed and deployed as a hotfix. Please download the hotfix here:
http://files2.visual-paradigm.com/200602/HotFix/20060128a/vpplatform.jar
The following article shows you how to apply the hotfix to your VP Suite:
http://resource.visual-paradigm.com/tips_and_tricks/general/replacing_hot_fix.html
If there are any further inquiry, please do not hesitate to contact me.
Best Regards,
