I use a fresh installation of Eclipse Europa (with JDK 6.0), and of SDE 4.1 Community Edition. Installation was so far without problems, but at the start-up I see the attached errors in the log file. And SDE is then not available in Eclipse.
Are there any ideas, how to solve the problem?
Regards,
Karl
!SESSION 2007-10-05 06:55:19.619 -----------------------------------------------
eclipse.buildId=M20070921-1145
java.version=1.6.0_03
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_CH
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.core.runtime 4 2 2007-10-05 06:55:50.834
!MESSAGE Problems encountered starting up plug-in: “org.osgi.framework.BundleException: The activator com.vp.vpsde.ec.VPSDEECPlugin for bundle com.vp.vpsde.ec is invalid”.
!STACK 0
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:141)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:970)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:346)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:260)
at org.eclipse.core.internal.runtime.InternalPlatform.start(InternalPlatform.java:877)
at org.eclipse.core.internal.plugins.PluginDescriptor.doPluginActivation(PluginDescriptor.java:360)
at org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin(PluginDescriptor.java:340)
at org.eclipse.ui.internal.EarlyStartupRunnable.getPluginForCompatibility(EarlyStartupRunnable.java:149)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:73)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2190)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3563)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.SWT.error(SWT.java:3452)
at org.eclipse.swt.widgets.Display.error(Display.java:1137)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:666)
at org.eclipse.swt.widgets.Display.addFilter(Display.java:517)
at v.svs.i(:110)
at com.vp.vpsde.ec.VPSDEECPlugin.(:112)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:136)
… 15 more
Root exception:
at v.svs.i(:110)
!ENTRY org.eclipse.ui 4 4 2007-10-05 06:55:50.837
!MESSAGE Unhandled Exception
!ENTRY com.vp.vpsde.ec 4 0 2007-10-05 06:55:50.837
!MESSAGE Unable to execute early startup code for an extension
!STACK 0
java.lang.reflect.InvocationTargetException
Caused by: org.eclipse.core.runtime.CoreException: Problems encountered starting up plug-in: “org.osgi.framework.BundleException: The activator com.vp.vpsde.ec.VPSDEECPlugin for bundle com.vp.vpsde.ec is invalid”.
at org.eclipse.core.internal.plugins.PluginDescriptor.throwException(PluginDescriptor.java:296)
at org.eclipse.core.internal.plugins.PluginDescriptor.doPluginActivation(PluginDescriptor.java:362)
… 9 more
Root exception:
org.eclipse.core.runtime.CoreException[2]: org.osgi.framework.BundleException: The activator com.vp.vpsde.ec.VPSDEECPlugin for bundle com.vp.vpsde.ec is invalid
at v.svs.i(:110)
… 15 more
!ENTRY org.eclipse.ui 4 4 2007-10-05 06:55:50.838
!MESSAGE Bad extension specification
!ENTRY com.vp.vpsde.ec 4 0 2007-10-05 06:55:50.838
!MESSAGE startup class must implement org.eclipse.ui.IStartup
