My configuration is ubuntu 10.10+jdk 1.6_24+vp 5.0_ent
It keeps dead under all kinds of unpredictable conditions,even after disabling compiz.That is killing me.But it works just fine under Kbubuntu 10.10 with same configuration. Can anybody tell me how to make it work smoothly.thank you.
I also have similar problem. But I use Gentoo.
I tried to run SDE from context menu of Java project. But with no result.
There are my logs attached. eclipse.log
It is recommended to use Sun JDK 1.6 or above. But since you already don’t have the system anymore, that means it is no longer able to diagnose the problem… I suggest you drop us a message if you experienced the problem again on other platform. Feel free to contact me if you need any help.
